Home made Cat Shields?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundraction, Dec 1, 2021.
  1. Dec 1, 2021 at 11:33 AM
    Tundraction
    Tundraction [OP] New Member
    Duane
    Minnesota
    2014 SR5 DBL MGM 4x4 5.7
    Phone Charger
    Hello Folks!
    Was curious if anybody has ever made their own Catalytic Converter shields?
    If so how did you do it? Link? Thanks in advance.
  2. Dec 1, 2021 at 11:37 AM
    RobertD
    Robert
    DFW, Texas
  3. Dec 1, 2021 at 12:06 PM
    2mchfun
    3/8" expanded metal here. My best idea is to just have a fab/machine shop save you a used bandsaw blade. Take the blade to a muffler shop and have them chop it into sections and weld it along the exhaust tubing either side of the cats. Being high carbon steel, a sawzall blade isn't going to allow a thief to remove your cats. Lightweight, affordable, effective, and you can still service your transmission easily too. Take a twelve pack to the nice guy at the machine shop when he calls you to pick up the blade!
  4. Dec 1, 2021 at 12:49 PM
    Tundraction
    Duane
    Minnesota
    Phone Charger
    RobertD, Unfortunately Classy63 is out of them. I have the same Idea of just using cardboard templates and then welding some plates together, have a mig and a cheapo plasma.
    2mchfun, Interesting idea, might try it.
    TaquitoBandito and 2mchfun like this.
  5. Dec 1, 2021 at 1:38 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    I prefer dual wielding cats but this may help:
  6. Dec 1, 2021 at 2:20 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
  7. Dec 1, 2021 at 5:11 PM
    Kbar691
    Kbar691 Hmmm
    Kenny
    2019 TRD Pro
    I have a template. I have been shopping for a sheet of 3/8 aluminum. Most want to sell an entire sheet. You can make 3 with a whole sheet. If I can find a few in Houston that like to build stuff and divide the cost of the sheet hit me up.
  8. Dec 1, 2021 at 5:54 PM
    Or you could make 3 of them and easily sell the other 2 I bet.....Just an idea.
  9. Dec 1, 2021 at 5:55 PM
    There is someone on here who made his own plate. I will see if I can find the thread.
    TaquitoBandito likes this.
  10. Dec 1, 2021 at 5:57 PM
  11. Dec 1, 2021 at 6:00 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    I made my own plate. Bought a sheet of 4x8 3/16 steel, cut in half to make a 4x4 plate. I bought some corrugated platic sheet from home depot because it's more rigid than cardboard, then made my template. I just improvised from there, adding what I needed for more protection.
    Mine is a single plate, 4 feet long. So it's very heavy, but that makes it a great theft deterrent as well. I had to use a floor jack to install it. For the rear I made my own brackets to give it rigidity for off road use. I didn't punch any holes for cooling yet. But temps are fine even pulling my camper. I also cut out a square under the transfer case and lowered it, and drilled holes in all four corners since that is where my ac condensation drips. I have a couple pics but not many
  12. Dec 1, 2021 at 6:02 PM
    I just linked your original post for him lol. :thumbsup:
  13. Dec 1, 2021 at 6:04 PM
    Sumo91
    TN
    You beat me to it while I was typing :rofl:
  14. Dec 1, 2021 at 6:04 PM
    BayRunner
    2017 Tundra Platinum
    He’s not out of them, but simply makes them to order. With all the options between material and powder coat it makes more sense to make each one from an order.
  15. Dec 1, 2021 at 6:38 PM
    Kbar691
    Kbar691 Hmmm
    Kenny
    2019 TRD Pro
    I considered that. I’m not really a make it and sell it guy. I don’t want to deal with any issues they may have.
    I considered perforated plate. Cooling holes would be automatic. Not sure on that price. I like the idea of aluminum But after reading the other post I may switch materials. Go with the 3/16 steel.
    The plywood template I made doesn’t cover the rear cats….but neither does valhallas. That is why I say you can get 3 shields out of a sheet.
    Ct. Rich likes this.
  16. Dec 1, 2021 at 6:48 PM
    RobertD
    Robert
    DFW, Texas
    My Valhalla's cover the rear...
  17. Dec 1, 2021 at 6:49 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I didn’t do this, mainly because I wanted skidplate type protection, but it looks like a pretty easy and very effective way to provide cat protection 485754F6-2E56-4DC3-9FFF-36A238FD46EA.jpg
    Wrap this stuff all around the cats and pipes, tie it up with a bunch of st st hog rings. Probably get it done for under a hunnert bucks
  18. Dec 1, 2021 at 6:55 PM
    2mchfun
    You can find somewhere that does surface hardfacing on things like digging machinery blades and downhole drilling tools. Have a bead of tungsten hardfacing laid on either side of the cats and be done.
  19. Dec 1, 2021 at 9:56 PM
    Tundraction
    Duane
    Minnesota
    Phone Charger
    WoW!!!! you guys are busy. I go away for a couple hours and bam! a million replies! Thank you all so much. I can tell this is a great forum.
    So I went to the steel yard and found a drop sheet of 12g 4ft x4ft. Not as thick as I would have liked but it will work.
    Made my template out of cardboard then transferred it to the Sheetmetal, cut it out and am in the process of test fitting and trimming.
    Need to drill mounting holes and weld on some side shields. This is for the front cats only. I will build another for the rears.
    When I measured before I started, I too like Sumo91 was going to make a full 48x48 plate but like he said its heavy. So decided to do in 2 pieces.Tundra on ramps.jpg Tundra cat shield template.jpg Tundra Cat Shield steel.jpg Tundra Cat Shield Steel 2.jpg Tundra on ramps.jpg Tundra cat shield template.jpg Tundra Cat Shield steel.jpg Tundra Cat Shield Steel 2.jpg
  20. Dec 2, 2021 at 5:35 AM
    Kbar691
    Kbar691 Hmmm
    Kenny
    2019 TRD Pro
    When I looked at them you had to buy a second piece to cover the back. I should have stated that I am only talking about covering the front. Dunno….maybe they have one that covers all now.
  21. Dec 2, 2021 at 5:58 AM
    Not bad! Post pics when all done. Yeah we don't play here in this forum as you can tell. There are a lot of awesome people in here so ask any questions that you need to. That's how we all learn about these trucks. I will warn you though.....you will catch crap if you ask "what size tire will fit" or "how can i improve mpgs" LOL.
    Kbar691 likes this.
  22. Dec 2, 2021 at 10:57 AM
    Tundraction
    Duane
    Minnesota
    Phone Charger
    Kbar691, he does have a front and rear cover listed on his website. I would have ordered from him but needed them now, my neighborhood is the worst in all of Minneapolis.
    Tundra234, noted on the tire size and mpg hehe. I will post more pics as I go and when finished.
    I had originally went to the steel yard to by a 4x4 sheet of 3/16 diamond plate, $319 before tax and weighed 140lbs Then asked if they had any drops of odd sizes, I found this roughly 4x4 sheet of 12g which is just 1/64 thinner than 11g and it was only $50 after tax and weighed 70lbs.
    I used the 2 rectangular holes at each side if the trans crossmember, installed some speed nuts marked and drilled some holes.
    I installed some speed nuts at the front cross member in 2 of the many round holes, marked and drilled forb bolt holes.
    More pics coming soon.
  23. Dec 2, 2021 at 11:12 AM
    Tundraction
    Duane
    Minnesota
    Phone Charger
    I think the speed nuts will be temporary until I can figure out a stronger less prone to rust/breakage mount system.tundra speed nuts.jpg tundra speed nuts 2.jpg
  24. Dec 2, 2021 at 11:15 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Your welcome haha
  25. Dec 2, 2021 at 11:26 AM
    Tundraction
    Duane
    Minnesota
    Phone Charger
    Hahaha, what ever works!
  26. Dec 2, 2021 at 11:49 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Did you do this or are you giving ideas? I'm intrigued by this but I can't picture in my head what it looks like.
  27. Dec 2, 2021 at 12:07 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    I'm intrigued by this, too...
    How well would it hold up to a carbide-toothed Sawzall blade?
  28. Dec 2, 2021 at 12:11 PM
    Tundraction
    Duane
    Minnesota
    Phone Charger
    Sumo91, I think yours is a better theft deterrent. after I'm done I may redo it like yours. That beast under there would be like a Pitbull staring them in the eye hehe. Oh and they do make 1/2 inch tamper proof bolts.
    https://www.globalindustrial.com/p/...et-head-18-8-stainless-steel-pkg-of-10?ref=40
  29. Dec 2, 2021 at 12:12 PM
    2mchfun
    No, I didn't. Not because I don't like it, but because I had already purchased 3/8" expanded metal to build a headache rack. Due to time constraints I settled for an aftermarket headache rack and the expanded metal was just in my way and needed to get used. Now if I didn't have the material, you bet, I would have been right on it.
    Jaypown[QUOTED] likes this.
  30. Dec 2, 2021 at 12:16 PM
    2mchfun
    It all depends on the actual material hardness, thickness, layers?, welding wire type, etc. Your average thief is going to have cheap shoplifted sawzall blades.
    BravoDeltaRomeo likes this.
