Home gutter guards
Discussion in 'Home Improvement' started by Bprose, Jun 8, 2020.
  1. Jun 8, 2020 at 2:36 PM
    Bprose
    Bprose [OP] Old member
    VA
    17 Tundra CM TRD
    Anyone on here ever put up rain gutter screens on their house? Any recommendations? Any stay aways? I’m in VA now, coming from so cal and AZ, nobody has gutters, or leaf guards because no rain or trees. What’s a good solution so I don’t have to clean the damn gutters.
  2. Jun 8, 2020 at 2:56 PM
    Bprose
    VA
    17 Tundra CM TRD
    Did you install yourself?
  3. Jun 8, 2020 at 2:56 PM
    P-Factor
    P-Factor New Member
    I have had LeafGuard on my house for seven years with great results. Never had to clean my gutters since installation. The only negative is under severe down pours and at valley locations only, they will not catch large volumes of water and over spill, but only on very rare occasions.
    https://www.leafguard.com/
  4. Jun 8, 2020 at 5:01 PM
    tye
    tye New Member
    tye
    2016 TRD Pro DC
    Diamondback cover, flowmaster exhaust, n-fab sliders
    If you have pine trees, don't waste your money. The needles slide in and cause clogs. I have read that they also cause ice dams in cold climates but I never saw a problem with that
  5. Jun 8, 2020 at 5:15 PM
    Ericsopa
    Ericsopa Old man and the sea
    I have had LeafGuard for about a year. Expensive, but it's worked very well so far. I am surrounded by post oaks and live oaks, so have two leaf falls per year, fall and spring. Too darned old to be up trying to clean the gutters anymore. It has such a fine stainless steel screen, that I would think it also works for pine needles
  6. Jun 8, 2020 at 6:04 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I bought some off Amazon and installed myself. Only problem is the live oaks when pollinating in spring and the pecan pollen clusters. Instead of constantly moving ladder i can just get blower out. I like to hang xmas lights on gutters so I skipped part of the front. Make sure when installing that you slope away from the house as much as possible.
  7. Jun 8, 2020 at 6:16 PM
    Kdogg77
    Kdogg77 If it ain't broke, it will be...
    Ken
    Central Cali
    2017 Tundra Crewmax
    6" RC suspension lift, 18" Pro Comp wheels, 35x12.5x18 tires, RC front/rear bumpers, RC Grill insert, Spider No Drill Roof Rack, Lighting by RC and Cali Raised. Interior mods include AJT Designs, Pioneer, and Rockford Fosgate.
    BE90B6A0-9BEB-434D-9DB2-65E63E021445.jpg These...on clearance at Lowe’s.
  8. Jun 8, 2020 at 7:10 PM
    Navi
    Navi New Member
    2019 CrewMax Limited
    Look up something called ShurFlo gutter guard. I have them, installed myself and they are excellent and very affordable..even cheap for the outstanding level of protection they provide.
    They’re not fancy, they just work.
    It’s not a micro mesh product either. My Dad has a micro mesh product and they are good too but i feel like ShurFlo outperforms them and are way cheaper too.
    They are sold by small independent gutter supply stores. got mine somewhere around the metro atlanta area
  9. Jun 8, 2020 at 7:37 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I would not use the micro mesh. They will clog with fine debris and gutters will not serve their purpose which is to direct water away from your foundation. Now if you are in areas where you don't have foundation issues due to soil then no big deal. In those cases why even have gutters. In DFW area gutters are critical to direct water away from foundations. Without gutters and proper drainage foundation damage is certain.
