Home AFCI Breaker Won't Reset. Any electricians out there?
Discussion in 'Home Improvement' started by Danimal86, Jan 1, 2023.
  1. Jan 1, 2023 at 8:47 AM
    Danimal86
    Danimal86 [OP] Looks clean even when its dirty!
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Northern Cal got a crazy storm that was raining like crazy, and got hit with 50mph winds.
    I woke up this morning and noticed that one room didn't have any power. Everything else in the home is just fine, but this one room. I went outside and saw that the breaker pannel had swung open in the wind. The weather is clear now so i have the panel open and the cover off. Nothing seemed that wet, but according to my home server, power went down in that room around 930pm and i think it was rainy/windy until close to midnight. I took the air compressor and tried to blow out any water. Some water came out from some of the breakers but wasn't too bad.
    The breaker is a Eaton BRCAF115. I unplugged everything in that bedroom from the outlets just to be safe.
    Anyone know if these things just need to dry out, or should i grab a new one? Some quick google searching, i'm having a hard time finding one locally. Can these be replaced with any AFCI?
  2. Jan 1, 2023 at 8:54 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    How old is that breaker? If it trips easy, the spring may be worn. Its cheap to replace....
    I'd seal the box better and maybe put dielectric grease on the terms.
  3. Jan 1, 2023 at 8:58 AM
    NWPirate
    Zach
    WA
    You said you unplugged stuff, are all the light switches off?
    Did you try to reset the breaker all the way off, sometimes it takes a firm push in the off position.
    You'll need the same Eaton breaker if you need a replacement, Cutler Hammer might work though cuz they are a sister company.
    If you feel comfortable, lift the wire from the breaker and try to reset the breaker without the circuit landed. If it still trips, the breaker got smoked.
    FrenchToasty likes this.
  4. Jan 1, 2023 at 9:02 AM
    Danimal86
    Daniel
    Sacramento, CA
    What do you mean about Lift The Wire? Like pop the breaker out?
    Yeah all the light switches are off
  5. Jan 1, 2023 at 9:03 AM
    Danimal86
    Daniel
    Sacramento, CA
    I pulled the breaker out and it will stay in the on positionPXL_20230101_170257925.jpg
    Edit: I was looking at the back of the breaker and water dripped out. Yikes
  6. Jan 1, 2023 at 9:07 AM
    Danimal86
    Daniel
    Sacramento, CA
    House is about 6 years old. never had any problem with it before.
    Yeah, gonna also put a nail through the latch moving forward
  7. Jan 1, 2023 at 9:09 AM
    NWPirate
    Zach
    WA
    Nope, pull the dead front off the panel to expose the all the breakers. You'll see a screw where the wire is landed, back that screw off a little with the breaker in the off position.
    ONLY if you feel comfortable in a hot panel. You could also turn your main breaker off and only the main breaker will have power
  8. Jan 1, 2023 at 9:10 AM
    NWPirate
    Zach
    WA
    Turn it off before you plug it back in
  9. Jan 1, 2023 at 9:10 AM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    Remove the ArcFault breaker and blow it out with some compressed air and reinstall.
    Chances are it's wet, they're sensitive (neutral/white wire).
    Or replace with a regular/ non arc and I bet it works. Land the neutral on the neutral/ ground bar if this is a metered main.
    My 2¢, not professional advice as I'm still foggy from last night's festivities.:drunk::D
    1lowlife and NWPirate like this.
  10. Jan 1, 2023 at 9:16 AM
    NWPirate
    Zach
    WA
    I would set a fan up in front of the panel and dry them out for a while. Be very careful, water dripping off the breakers could ground the bus bar.
    I would turn off all the breakers you can when drying it out
  11. Jan 1, 2023 at 9:22 AM
    Danimal86
    Daniel
    Sacramento, CA
    Ok, i've got the breaker hanging down with one corner pointing down and a couple drips came out. Gonna let it sit like that for an hour or so.
    Should i back both wires out or just one? Just back it off and re-seat the wire(s) or do something else? I've got some Wera insulated screwdrivers so its time to use them for their actual purpose. lol
  12. Jan 1, 2023 at 9:23 AM
    Danimal86
    Daniel
    Sacramento, CA
    I'm hoping its just wet. I've got it hanging down right now and a few drops of water came out. I'll hit it with some more air in an hour or so. i'll really hit the white wire area.
    B.Ross[QUOTED] likes this.
  13. Jan 1, 2023 at 9:30 AM
    NWPirate
    Zach
    WA
    No, it should be good hanging like you have it. Just make sure to turn the breaker off before plugging it back in
  14. Jan 1, 2023 at 9:38 AM
    Danimal86
    Daniel
    Sacramento, CA
    NWPirate[QUOTED] likes this.
  15. Jan 1, 2023 at 9:56 AM
    NWPirate
    Zach
    WA
    ColoradoTJ likes this.
  16. Jan 1, 2023 at 9:58 AM
    Danimal86
    Daniel
    Sacramento, CA
    Ok, i'll go grab one.
  17. Jan 1, 2023 at 10:00 AM
    NWPirate
    Zach
    WA
    You might be fine though after it dries out, give it a try before you open the new ones.
  18. Jan 1, 2023 at 10:11 AM
    Damn that’s pretty scary stuff. I’ve had a 480V arc flash and that was very violent. Lucky I had all PPE gear on. I’ve seen a 12470V phase to ground and a 230KV phase to ground. That will make you believe in a God….or at least make one run around in circles screaming like a little girl.
    Like @NWPirate suggested…get another breaker. Hell..pick up a few
  19. Jan 1, 2023 at 10:12 AM
    @bmf4069 you're an arcy sparky magic wielder, aren't you?
    bmf4069, FrenchToasty and NWPirate like this.
  20. Jan 1, 2023 at 10:15 AM
    Danimal86
    Daniel
    Sacramento, CA
    will do.
    So i'm trying to decide if i should cancel the Amazon order for the same exact breaker, is it true that its not good to have more than one gfci outlet inline? So if a breaker were to die for a bathroom circuit that has a gfci outlet on it, then i would not be able to use an AFCI/GFCI breaker for a replacement and it would just need to be an AFCI breaker?
    If thats true, then i wont cancel it, because it looks like its not easy to find a AFCI only replacment locally (they are all AFCI/GFCI), so it would be smart to keep a spare.
  21. Jan 1, 2023 at 10:17 AM
    NWPirate
    Zach
    WA
    480v porn from work this week. :headbang:
    Testing out a new chicken switch. This will rack, charge, close and trip our station service breakers.
  22. Jan 1, 2023 at 10:18 AM
    Danimal86
    Daniel
    Sacramento, CA
    Wowza! You got bigger nuts that i do! I'm comfortable around 110v, anything more than that.....time to call in the pro's.
    And if after it dries and it still doesn't work, i'll be wearing some gloves and eye protectors for sure...and like a mentioned before, i have Wera insulated screwdrivers.
    Good call on having a couple extras....suckers aren't cheap though.
    ColoradoTJ[QUOTED] and NWPirate like this.
  23. Jan 1, 2023 at 10:20 AM
    You will really enjoy those remote racking devices. We have them for all 480v-4160v….well, when people use them.
  24. Jan 1, 2023 at 10:23 AM
    NWPirate
    Zach
    WA
    You can, but it's not necessary. You have to wire them up in parallel on the line side if you do
    ColoradoTJ and FrenchToasty like this.
  25. Jan 1, 2023 at 10:31 AM
    TheBrit
    TheBrit Wrinkly member
    Mark
    2013 Double Cab Tundra 2WD stuckinthemud
    I find it hard to believe that you have a six year old house with a breaker panel on the outside of the house. Is that normal practice in many states, I haven't seen that kind of thing on any newish (nor older) houses in the South East?
    landphil likes this.
  26. Jan 1, 2023 at 10:31 AM
    NWPirate
    Zach
    WA
    Yeah, it worked pretty sweet.
    Part of me doesn't like giving that up though, I like suiting up.
  27. Jan 1, 2023 at 10:45 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Was thinking the same, regardless of the age of the house.
    Though it could be handy if your neighbours are thumping the tunes during a rowdy party when you’re trying to sleep. Click. :anonymous: What’s that noise? :D
    JLS in WA and NWPirate like this.
  28. Jan 1, 2023 at 10:46 AM
    Still can…:D
  29. Jan 1, 2023 at 11:10 AM
    B.Ross
    B.Ross New Member
    Southern Utah
    I see your 480V porn and raise you a commercial microwave.
    :anonymous:
  30. Jan 1, 2023 at 11:13 AM
    NWPirate
    Zach
    WA
    Oh yes :D
    Just hope the company doesn't come up with a remote racking policy
