Holding gears when cold
Discussion in '2nd Gen Tundras (2007-2013)' started by alexusw, Feb 5, 2022.
  1. Feb 5, 2022 at 1:42 PM
    alexusw
    alexusw [OP] New Member
    2007 Desert Sand Mica Tundra LTD
    I’m still trying to learn my Tundra. Is it normal for it to hold gears when the engine/transmission is cold? I notice when I leave in the morning it stays at 2000rpm for a couple of seconds then shifts back normal but this is only when it’s cold. Also I really want to have a piece of mind when it comes to the transmission. It’s a high mileage 07 with a detailed Carfax history. I can see that it has been serviced regularly, for example it has 5,000 mile service and so on. The last service I saw was the 120,000 mile service and spark plugs replaced. Still no specific detail that the transmission has ever been serviced. I had the dealership inspect the fluid last week. It’s dark but has hints of red. I was thinking that I could do a slow method drain and fill. Change the filter, replace pan gasket, drain only small amounts of old fluid and put in same amount of new fluid. See what it does and repeat as needed.
  2. Feb 5, 2022 at 1:43 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Normal
    alexusw[OP] likes this.
  3. Feb 5, 2022 at 1:50 PM
    t.friddy
    t.friddy New Member
    Charlotte, NC
    2019 Tundra SR5 DC
    Yea I’ve noticed this on 3 different tundras I’ve had. Normally lasts a few miles for me of holding lower gears.
  4. Feb 6, 2022 at 7:20 AM
    Jdubu
    Jdubu New Member
    Jon
    Glenford Ohio
    2008 double cab sr5
    Auxbeam light bar, 18x9 helo wheels with 33in Cooper discovery, full kicker sound system, dual glass packs dumped out the side, debadged, spray in bed liner, gator tri fold tonneau cover, Westin steps, blue door lights, led interior conversion, ble led grille and rock lights
    I had same deal, hooked in my truck one day when it was about 40 out and it took forever to het out of first. I started panicking thinking my trans was going out but read that if it's not to a certain temp it does this
