Hitch lock and coupler lock
Discussion in 'Towing & Hauling' started by Breathing Borla, Jul 24, 2023.
  1. Jul 24, 2023 at 9:27 AM
    Breathing Borla
    Breathing Borla [OP] I'd rather be fishing
    AZ
    Hey guys,
    any recommendations for a ball mount lock and also coupler lock?
    right now I just use cotter pin for ball mount and the pin the came with the trailer for the coupler.
    I would like two sets and two keys and made in USA is a must
    any suggestions?
    Thanks
  2. Jul 24, 2023 at 9:38 AM
    Proven Industries makes good stuff....expensive though.
  3. Jul 24, 2023 at 11:47 AM
    Breathing Borla
    AZ
  4. Jul 24, 2023 at 11:59 AM
    Richie68
    Richie68 New Member
    2013 paltinum crewmax
    AZBoatHauler likes this.
  5. Jul 24, 2023 at 1:02 PM
    Breathing Borla
    AZ
    I kinda like the ones that have the redundant cotter pin so your not just counting on the lock to hold it on
  6. Jul 24, 2023 at 3:02 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
  7. Jul 24, 2023 at 3:13 PM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    I have had one similar to this one for the last couple of years and it has served well. Just pull the cap off and use a little oil or graphite in the key hole every year.
  8. Jul 24, 2023 at 3:23 PM
    Breathing Borla
    AZ
  9. Jul 24, 2023 at 3:28 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Yeah, I didn't bother to check. This was the best looking stuff available at my local hitch shop.
  10. Jul 24, 2023 at 3:30 PM
    Breathing Borla
    AZ
    your right , looks awesome, likely the best on the market , but I have to decide if I want to spend that much
    https://www.provenlocks.com/products/receiver-hitch-lock-model-hl1?variant=37678392967364
    I don’t see the coupler lock there though that locks the latch down , small pin type
    i also wonder if that’s too wide to get at and will be behind the bumper portion of that area
  11. Jul 24, 2023 at 3:33 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Could be other options, depending on how your hitch is set up. My dad just uses a regular combination lock on his boat trailer.
  12. Jul 24, 2023 at 3:36 PM
    Breathing Borla
    AZ
    Ya I’m trying to get key alike which would be handy , also want to buy once and be done type deal
    right now that lockitt set looks pretty good, made in USA , can get them same keys, has redundant cotter pin , not completely stupid pricey
    And the key faces out so I think that would be easier
  13. Jul 24, 2023 at 3:47 PM
    Aswongsc
    Aswongsc New Member
  14. Jul 24, 2023 at 4:01 PM
    Breathing Borla
    AZ
    From Canada eh?
    Ok had to say it , ha
    looks nice, pretty pricey
    do you have a gen 3 and if so does it work well with the room down there and the bumper indent or are you fighting it if you have big paws?
  15. Jul 24, 2023 at 4:23 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
  16. Jul 24, 2023 at 4:43 PM
    FuegoMCS
    FuegoMCS New Member
    East Texas
    2011 Crewmax 2WD
  17. Jul 25, 2023 at 8:03 AM
    Hugemoose
    Hugemoose New Member
    David
    Philly
    2016 Tundra Crewmax
    Not enough....
    Most trailer locks are very easily broken. As mentioned, Proven industries has probably the best lock design on the market, but you'll pay for it.
    I use this design with a ABUS diskus lock. https://www.amazon.com/Blaylock-Ame...roducts&qid=1690297035&sr=8-2#customerReviews
    A good puck lock would work too. Again, any determined thief can still pry or cut this off with the right tool. It just helps keep honest people honest.
    I don't normally bother with a ball mount lock since I don't like how many are designed, and aren't often solid pieces of steel. I just remove the hitch when not in use.
  18. Jul 25, 2023 at 8:12 AM
    Breathing Borla
    AZ
    thanks guys, I guess I didnt title that right, I wasnt looking for that style of hitch lock.
    I meant more of the kind that keeps the trailer couple latch down and locked to be used when actively towing, so when you stop or overnight with it still attached its not as easy as just pulling a pin, at least this would slow or deter
    I think Im going to go with that lockitt set match keys so far
  19. Jul 25, 2023 at 8:37 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
  20. Jul 25, 2023 at 8:53 AM
    Breathing Borla
    AZ
    lol, hot knife meet butter
    anything can be beat, Im not looking for that much security, just keep the dumbasses from walking away easily
    Cpl_Punishment likes this.
  21. Jul 25, 2023 at 8:55 AM
    Breathing Borla[OP] likes this.
  22. Jul 25, 2023 at 8:58 AM
    Breathing Borla
    AZ
    Im guessing someone could jsut take a sawzall and slide it between and lock and the coupler latch if they really wanted to, but its better than jsut a pin you slide out which is all I have now
  23. Jul 25, 2023 at 9:26 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    that dude could open anything in a min...lol
  24. Jul 25, 2023 at 9:30 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
  25. Jul 25, 2023 at 9:48 AM
    2mchfun
  26. Jul 25, 2023 at 9:50 AM
    Breathing Borla
    AZ
    EdMal01 and 2mchfun[QUOTED] like this.
  27. Jul 25, 2023 at 10:04 AM
    2mchfun
    That's cool, I totally get it! However, unfortunately you are still probably going to be supporting China in multiple ways, just the facts if you see the bigger picture. Good luck!
  28. Jul 25, 2023 at 10:21 AM
    Hugemoose
    David
    Philly
    2016 Tundra Crewmax
    Not enough....
    Gotcha, and yes those look very nice. You're right any slightly determined thief can still get through it easy, but it will deter some sticky fingers at least. That hitch pin looks nice too, and solid. I normally don't use those as most seem cheap and and easily broken off.
    For my coupler latch I use a small brass Master Lock branded one. It works fine, but that one you found is a nicer looking unit. upload_2023-7-25_13-20-13.png
  29. Aug 5, 2023 at 12:01 PM
    Breathing Borla
    AZ
    Ok got my stuff from lockitt
    it’s super nice, fits perfect and with the key hole facing out you can get to it easier , no more busted knuckles
    All keys are alike for both locks and you get nice large sturdy keys , 4 of them
    thumbs up!
  30. Aug 5, 2023 at 12:03 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Oof it’s blocking the already hard to reach chain hook
