HIREV Sports (HRS) Led Taillights Review with Pictures
Discussion in 'Lighting' started by BayRunner, Feb 1, 2021.
  1. Feb 1, 2021 at 7:56 AM
    BayRunner
    BayRunner [OP] I’m here, except when I’m not
    2017 Tundra Platinum
    Someone on another thread pointed out these new LED taillights and I decided to give them a look. A relatively newcomer to the Tundra aftermarket light vendor, but it looked interesting. Here are my thoughts based on my experience.
    Vendor: HIREV Sports https://www.hirevsports.com/
    Lights: HRS 2014-20 Toyota Tundra LED Tails Lights
    URL: https://www.hirevsports.com/collections/tundra/products/hrs-2014-20-toyota-tundra-led-tails-lights
    Ordering Process: The ordering process was extremely easy.
    Shipping: I was actually kind of shocked that I received a shipment notification email just a few hours after placing my order. I ordered on a Wednesday and it was at my door on Friday.
    First Impression: The lights were well protected in a sturdy box. I thought the build quality was good. I've been running the Spyder LED taillights for a while now and thought the HRS lights were slightly better build quality. The fit on the truck was also good.
    Installation: The installation was super, super easy. These lights are truly plug and play. Simply remove the old lights, unplug the 3 wires and plug the truck harness wires into the new light. There is no way of messing this up. Unlike the Spyder lights that require the re-use of the OEM backup light and light sockets, the HRS light does not. All lights are built in and is truly plug and play.
    Special Features: You have the option for sequential turn signals upon the order proses. The sequential is a bit unique in that the turn signal is an amber strip of LEDs that wrap around to the side of the light fixture. When the turn signal is activated, the whole strip turns on, however, the sequential movement is a higher intensity of light that moves from the inside to the outside of the strip ending with a bright "ping" type affect on the outer edge of the light assembly. There is also a brief animi nation affect when the lights are first turned on that lasts about 2-3 seconds.
    Overall Impression: I was pleasantly surprised with these lights and I like them a lot. I think they are a true contender for aftermarket taillights and are offered at a decent price point. My initial only suggestion for improvement would be to wrap the wires in a wire mesh loom, but this is simply a personal preference I have for wiring.
    Note: The pics below with side by side comparison shots are with the Spyder aftermarket lights and not OEM.
  2. Feb 1, 2021 at 8:03 AM
    tundrasportinMA
    tundrasportinMA New Member
    Western Mass
    2019 Tundra Sport DC
    6112/5160 , SCS Ray 10's, Cooper Discover AT3 -295/70/18, Dirty Deeds 8inch, N-Fab Podium
    Thanks for a great write up. I like the look of them and have been considering trying them out. For the sequential turn signal, you mentioned that is an option, did you go with it? I am thinking that is what the last couple pictures are trying to show but I wasn't sure.
  3. Feb 1, 2021 at 8:06 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    I'm digging them, but where's the love for the 2nd Gens :pout:
    D4x4TRD and nags like this.
  4. Feb 1, 2021 at 8:13 AM
    BayRunner
    Yes, I went with the sequential turn signals. You are correct that since I could not upload a video, I attempted to convey the turn signal in the last 2 pictures. The second to last is the snapshot of when the turn signal turns on. The last picture is the final "ping" affect when the bright intensity reaches the outer end.
  5. Feb 1, 2021 at 8:14 AM
    BayRunner
    Reading the reviews on their web site and the responses by HIREV Sports, it appears that they are pleased with the response from the Tundra world and are planning other products for the Tundra. I would suggest contacting them and voicing your input to encourage them.
    rons23[QUOTED] and RobertD like this.
  6. Feb 1, 2021 at 8:34 AM
    NuTundra18
    NuTundra18 New Member
    Jimmy
    2020 TRD Pro CM - MGM
    Toyota OEM Hard Flip Tonneau, Predator Steps, Driver Grab Handle, Console Sage, Spray Berliner.
    BayRunner - great write up and thank you. Do you happen to have a side pic of these lights when they are off. I’m trying to see what the look like from the different angles on “CBD” on the MGM paint. Also did you happen to have LED bulbs installed in your front headlights? I know the tundras rear tail lights will hyperflash when changing fronts signals to LED, wanted to see if I would have an issue with these if I did go with them. I know on their own they are fine but combo them with front LEDs not so sure. Thanks
  7. Feb 1, 2021 at 8:49 AM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    I wish folks would stop using the dot matrix type diode sections.
    Makes the lights look cheap. They have the really nice curved diodes with no hot spots and then right in the middle of them have 6 individual diodes.
  8. Feb 1, 2021 at 8:49 AM
    Hmmmmm.........:thumbsup:
  9. Feb 1, 2021 at 8:51 AM
    RobertD
    Robert
    DFW, Texas
    Awesome job! It's great seeing these compared to one of the popular aftermarket tail lights as well. Hope these last you a good long while!
  10. Feb 1, 2021 at 8:54 AM
    BayRunner
    I use the OEM LED headlights. However, since the turn signals in these taillights are sequential, these use a built in LED controller. Thus no hyper flash. Hyper flash is typically caused when changing out the bulbs thus needing a capacitor.
    WawaLunar, Tundrastruck91 and RobertD like this.
  11. Feb 1, 2021 at 9:07 AM
    NuTundra18
    Jimmy
    They really do look good on the MGM, thanks for pics. It’s just a tundra thing I believe. I tried doing the spyders in the rear but because I changed the front turn signals to LEDs from VLEDs, the rear spyders hyperflashed. Makes me nervous to order these up and have same issue.
  12. Feb 1, 2021 at 9:37 AM
    BayRunner
    Guess you’ll just have to try it out and let the rest of us know the outcome :)
  13. Feb 1, 2021 at 9:37 AM
    NuTundra18
    Jimmy
  14. Feb 1, 2021 at 11:05 AM
    ebpgh
    ebpgh .
    PA
    2020 Cement Tundra
    How bright are the reverse lights? I'm guessing you go the clear version.
  15. Feb 1, 2021 at 11:28 AM
    BayRunner
    All of the lighting is very bright. The reverse lighting is brighter that what I had which was LED bulbs.
    Yea, I got the clear lenses for safety reasons. I wanted to make sure the red lighting is as visible as possible.
  16. Feb 4, 2021 at 2:08 AM
    2020TundraTRDSport
    2020TundraTRDSport New Member
    MGM 2020 Tundra TRD Sport
    Current Mods: -Add a sub wiring kit from tacotunes.com (to support OEM headunit) -Single 12” Kicker Solo Baric L7 ported box -Matte Black Emblems complete replacement (iForce, Tundra badges) -20” OEM wheels Bronze Vinyl wrap -Matte Black TRD 4x4 Sport Vinyl for bedsides -Red, Orange, Yellow Vinyl Heritage Decals for 2018-2020 Tundra Honeycomb Grille -AmeriLite Black Led Tail Lights with Fiber Optic running lights -VHT nite shade 1/2 in border around tail lights -Carbon Fiber Vinyl for 3rd brake light -Headlight Revolution Complete LED Upgrade Kit (Front turns, Reverse lights, Cargo lights, 3RD Brake light, Dome lights, Mirror lights, Plate lights, footwell light.) -VLEDs 07-UP Toyota Tundra Front Footwell LED Light Kit (Front and Rear) -Diode Dynamics SS3 Fog Lights (Yellow) -Ceramic Tint: Front 20%, Rear 5%, windshield 50% with 5% ASR strip Wish list mods: -BakFlip Tri-fold tonneau cover -Tundra 3UR-FE 5.7L V8 Supercharger System (Magnuson Supercharger) -7” BDS lift kit -BMC (Body Mount Chop) -Fuel Covert Bronze 18x9 +1 offset wheels -BF Goodrich KM3 37/12.50r18 -Honey De 4” Widebody Fenders (Paint Match) -Dawn Custom Style Truck Cab Top Spoiler (Paint Match with Fiber Optic Led 3rd brake light across the entire edge of spoiler end to end) -Bora 1.75” Wheel spacers -Dirty Deeds BAMuffler 6 in exhaust system with Matte Black Tip -Putco Blade Red 60” tailgate light bar w/ plug and play harness -Hood Bulge 40” Baja Designs S8 Driving/Combo Yellow light bar -Lower grille 40” Baja Designs S8 Driving/Combo White light bar -Ditch lights Baja Designs LP6 Driving/Combo Yellow Pods -Baja Designs FPK (fog pocket kit) White fog light pods -Baja Designs OnX6 10” white light bar x2 back up lights (under rear bumper)
    Would it be possible to upload a video of the full functions of these tail lights on YouTube or Instagram with a link? I would really appreciate it if you could. You would be the first person to have a video of these tail lights anywhere. If that is not a possibility my questions then are:
    •Is the running light and the brake light the same lights?
    •Is there a significant noticeable difference between the park light and the brake light when applied?
    •Is the chrome sections on the housing the reverse lights?
    •Is the turn signal bright and noticeable in the day from a distance?
  17. Feb 4, 2021 at 6:01 AM
    tundrasportinMA
    Western Mass
    @Jim LE 1301 had posted a video of them in another thread, link below. Not sure it answers all your questions but it gives you an initial look at them.
    tonedraw likes this.
  18. Feb 5, 2021 at 1:16 PM
    BayRunner
    min summary, the top chrome area is the break light but is actually red. The bottom chrome area is the reverse light.
    No, the top chrome area is the red break light
    Yes
    Only the bottom one
    Yes
    Pictures:
    • Running lights
    • Break
    • Reverse
    WawaLunar and RobertD like this.
  19. Feb 5, 2021 at 1:58 PM
    NuTundra18
    Jimmy
    Looks great!
  20. Feb 5, 2021 at 6:25 PM
    2020TundraTRDSport
    Thank you for the pictures and the answers to my questions. Those are really cool lights. I am going to be ordering a pair for myself.
  21. Mar 16, 2021 at 11:58 PM
    Par2381
    Par2381 Member
    Any of you guys have this issue?
    This is the first set
    This is the replacement they sent out
  22. Mar 17, 2021 at 12:22 AM
    Par2381
    Par2381 Member
    I went with BRB(Black Lens). The lights are beautiful. They are very bright at night and visibility to other drivers will not be an issue. I have zero complaints on the functionality and looks of the light themselves. The damages to the lights on the other hand is a bit annoying. They've been quick with the responses and shipping out the replacement tail light. I'm curious to what they will do now knowing the replacement had the same defect. I'm not sure if the pictures show it clearly but it's at the same location. The problem doesn't seem to be the padding inside and the the box wasn't crushed or anything. I'm leaning towards they just received a bad batch but they should be inspecting them before shipping.
  23. Mar 21, 2021 at 2:30 AM
    Par2381
    Par2381 Member
    I got an update from HIREV Sports. All the lights they have has this issue currently.
  24. Mar 24, 2021 at 1:00 AM
    Par2381
    Par2381 Member
    They said they will have a new batch in 2-3 months.
  25. Mar 25, 2021 at 3:39 PM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    hmmm I wonder if they'll discount the imperfect batch, my truck is dirty half of the time, I don't mind that imperfection.
  26. Apr 7, 2021 at 10:34 AM
    AMO_Tundra
    AMO_Tundra New Member
    TJ
    Hernando, MS
    2017 Super White Tundra Crewmax
    SDHQ Dual Battery System FRAC Harness Tacoma TRD Manual Shifter Mod w/Boot Diamondback SE Cover Front Runner Bed Rack Engine Mounted ARB Compressor Raptor Grille Light Mod 3wlines Power Window Mod Color Matched Door Handles Color Matched Mirror Caps
    They won’t I already asked them, I sent another email for an update on the new batch but no reply yet. But I was told by them that they are releasing a video showing how to fix the issue and it not noticeable so that’s why they aren’t discounting them.
  27. Apr 7, 2021 at 10:42 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Here's the sequential turns and startup sequence if anyone is still interested...
  28. May 15, 2021 at 1:46 AM
    Islandboy_671
    Islandboy_671 #gotte'y sibesa-hu
    Toby
    Lacey, WA
    2016 SR5 Tundra TRD Inferno
    8" ReadyLift w/ Bilstein Coil-overs and Rear Shocks, BAM 8" Exhaust, Stillen CAI, Coach-Builder Steering Kit and 3" Rear Shackles, Tech12Volts Remote Start and JBL speaker Upgrade system, Pioneer DMH-WT8600NEX HU, 3W Liners window mod, Morimoto XB LED Headlights, RC 30" Light Bar, RC 2" x4 cube LED's, HRS Smoked Sequential Tail Lights, Mammoth Guards Kryptek Gap Guards, Fab Fours Matrix Front Bumper, Fab Fours Vengeance Rear Bumper...
    So far one of the better tail lights IMO besides the molding imperfections like in the pics above but overall glad to have purchased these when they first were released!
  29. May 15, 2021 at 6:11 PM
    AMO_Tundra
    TJ
    Hernando, MS
    I’ve got the smoked version and I think they are great, the best ones I’ve had. I also have the same ones in my girlfriends FJ.
  30. May 16, 2021 at 6:32 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Is that hyperflash on the turn signal or just a product of the conversion to GIF?
