High pressure hose replacement getting parts
Discussion in '1st Gen Tundras (2000-2006)' started by Toyoto2003, Aug 8, 2024.
  1. Aug 8, 2024 at 8:50 AM
    Toyoto2003
    Toyoto2003 [OP] New Member
    Kevin
    2003 toyoto tundrasr5 offroad
    Hello I am replacing steering high pressure lines on 2003 tundra I am running into a problem at all the auto parts stores when trying to get both lines they are saying both different part numbers come up as the same part # the only help I may have gotten was from a Napa parts store they backtracked the part number of one and said the correct part may have been remained to us same part for both hoses just use a different route to run the line to make it work I don't have 500 $ to get a oem from toyoto any help would be appreciated
  2. Aug 8, 2024 at 9:07 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Toyodiy.com
    plug in your VIN and it'll give you parts #'s. I'm not 100% if the parts#'s are updated though.
  3. Aug 8, 2024 at 9:21 AM
    Toyoto2003
    Kevin
    They did when I looked at pictures from both p/n one is different looking same fittings at Napa they had two different looking parts on computer file but when they pull the part from stock it is the same part Napa backtracked the number it showed up as different they think they changed number to only sell the one part and say just reroute the hose so it will fit on truck I am trying to find out if anybody had this problem and if it works Napa called other stores to check there stock and same part for both part numbers shows up
  4. Aug 8, 2024 at 10:06 AM
    FishNinja
    Lee
    06DC2wd
    Why not use rock auto? You can cross reference part #'s on their site. And members have had luck with the sunsong (sp?) brand from RA.
    I've honestly heard nothing good about NAPA except they have re-man Denso parts on hand
  5. Aug 8, 2024 at 11:21 AM
    Toyoto2003
    Kevin
    I got the one pressure line from rock auto they don't have other one listed on there site I only found one on carrad. Com that looked like picture I had of part I am looking for was a oem part 400 dollars
  6. Aug 8, 2024 at 11:29 AM
    FishNinja
    Lee
    06DC2wd
    Sounds about right. I saw one go for like $550.
  7. Aug 8, 2024 at 11:37 AM
    Toyoto2003
    Kevin
    Is why I trying to find out if I could use the other line and reroute it another way to fit it makes me wonder if it can be done when all part supplers except Carrad say both part numbers are the same part and Napa has picture of part but they gave it a new number when they looked up old number they can only say the part might be able to used
