high oil pressure after oil change.
Discussion in '3rd Gen Tundras (2022+)' started by e263rd, Jul 25, 2025.
  1. Jul 25, 2025 at 2:14 PM
    e263rd
    e263rd [OP] New Member
    History... changed at 1000, 5000,10000,15000, 20000 all at dealership with their oil.
    25000 done at a mechanic shop with Kirkland 0-20 and OEM filter.
    If my memory serves me, analog oil pressure gauge always remained around the 1/2way mark no matter how I was driving.
    After last change, it fluctuates between 1/2 and 3/4 depending on RPM until the engine shifts to higher gears and then around 1/2 steady at 65mph.
    Idles at about 1/2 and then jumps up to 3/4 for and stop and go driving.
    -Could the different brand but same viscosity be responsible??? (sounds crazy)
    -Could the shop have overfilled the oil?
    I didn't ask for the .3qt back as I gave them 8 qts.
    -Could and extra .3qt with an incomplete drain be the problem?
    Oil is so clean and clear it's hard to get a good reading, but it seems to be at a MINIMUM at the "full mark on the dipstick".
    Frustrated with the change in gauge reading....
    Thanks for any input,
    E
  2. Jul 25, 2025 at 3:48 PM
    SWB Tundra
    SWB Tundra New Member
    T
    Cenral Arkansas
    2024 Tundra Platinum 4x4 CM Hybrid
    Over fill is not going to make oil pressure higher. Let it sit overnight and check it in the morning before you start it. Sounds fine too me.
    e263rd[OP] likes this.
  3. Jul 25, 2025 at 3:52 PM
    WineryCowboy
    WineryCowboy New Member
    2022 White Tundra SR5
    Timbrens SES Rear
    One time I accidentally mixed in one jug of 0w20 with 5w30 and the oil pressure gauge was 3/4 of the way. Immediately changed it and it went back to its normal.
  4. Jul 25, 2025 at 4:05 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
  5. Jul 25, 2025 at 5:36 PM
    GREENPUS
    GREENPUS New Member
    Scott
    2024 Black Tundra Limited TRD Off-Road
  6. Jul 25, 2025 at 5:54 PM
    JDAZ
    JDAZ New Member
    NJ
    2022 Lunar Rock TRD Limited
    Chrome Delete, TRD Pro Grill with BD light bar & OEM switch Beatsonic Amp Undercover armor flex cover
    Oil pressure should fluctuate with RPM. I would be worried if it didn't
  7. Jul 28, 2025 at 7:47 AM
    messagelost
    messagelost New Member
    FSD
    2023 Tundra Platinum HV
    I noticed oil pressure was staying around 3/4 instead of 1/2 after I changed oil, it settled back down to 1/2 after some driving.
    I thought the same thing, that I overfilled, but that was not the case. My theory is the oil filter was not yet saturated and air had to get fully pushed of the media maybe?
  8. Jul 28, 2025 at 11:03 AM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    I use Kirkland now. Had the same higher gauge reading after oil changes with Mobil1 too. Same on all my vehicles. Higher for the first 500 miles or so then it settles.
