High Miles Upgrades?
Discussion in '1st Gen Tundras (2000-2006)' started by T-Mitch, May 1, 2020.
  1. May 1, 2020 at 5:06 PM
    T-Mitch
    T-Mitch [OP] New Member
    TM
    2002 Tundra 4WD TRD
    Camper Shell/racks Bilstein 5100 Leveling shocks New radiator
    Hello,
    i have a 2002 Tundra 4WD TRD and it now has 235,000 miles. I know it has a lot of life in it so I want to make it last as long as possible.
    i plan on taking a really long road trip in it and I want to make sure it’s ready for pavement and some off road. Any ideas for performance upgrades or maintenance?
    Thanks
  2. May 1, 2020 at 5:17 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I would start with suspension repairs. What have you replaced thus far? Ball joints are a must. Front coilovers, rear shocks, leaf springs, tie rods, etc.
    MrAristo likes this.
  3. May 1, 2020 at 5:22 PM
    T-Mitch
    TM
    2002 Tundra 4WD TRD
    Good stuff, I have only replaced shocks, Bilstein 5100’s to level it out
  4. May 1, 2020 at 6:29 PM
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    Most importantly is timing belt and ball joints!!
  5. May 1, 2020 at 8:25 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I Second this
  6. May 1, 2020 at 8:36 PM
    Spark plug and battery refresh?
  7. May 1, 2020 at 8:41 PM
    stevechumo
    stevechumo New Member
    Most suspension and steering parts should be replaced including upper & lower control arms, upper and lower ball joints, inner & outer tie rods, sway bar bushings, stabilizer bar links, rack & pinion bushings, and shocks, and rear shocks. Also, steering & transmission fluid need to be replaced. Timing belt, water pump, spark plugs, valve cover gaskets. Then maybe radiator and starter if you're a hardcore. :)
    3.4Tundra and MrAristo like this.
  8. May 2, 2020 at 4:25 AM
    Professional Hand Model
    Hand Protectors
    Darkness and Rex Kramer like this.
  9. May 2, 2020 at 6:23 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    A new radiator would be cheap insurance.
