High miles transmission question
Discussion in '2.5 Gen Tundras (2014-2021)' started by reddog4245, Oct 31, 2024.
  1. Oct 31, 2024 at 7:42 AM
    reddog4245
    reddog4245 [OP] New Member
    Doug
    Kentucy
    2014 SR5 TUNDRA
    2014 SR5, 186k, bought it at 148k. Not sure of prior transmission maintenance. Will a drain and fill suffice without dropping pan?...or cleaning strainer...(Pan bolts a little rusty, concerned about them breaking). Thanks in advance!
  2. Oct 31, 2024 at 7:46 AM
    Retired...finally
    I would just concentrate on doing a few drain and fills. Pan bolts are probably in for good by now.
    reddog4245[OP] likes this.
  3. Oct 31, 2024 at 7:48 AM
    reddog4245
    Doug
    Kentucy
    2014 SR5 TUNDRA
    Ok on strainer??
  4. Oct 31, 2024 at 7:51 AM
    wouldn't bother changing the strainer, it's not really a filter, it keeps the chunks out, they are usually spotless when people change them anyway. Drain and fill is a safe way to introduce some new fluid with a fresh batch of lubricant and friction modifiers. Doing a drain and fill with your next few oil changes will do a good job of getting mostly fresh fluid in.
    blackdemon_tt and reddog4245[OP] like this.
  5. Oct 31, 2024 at 7:52 AM
    reddog4245
    Doug
    Kentucy
    2014 SR5 TUNDRA
  6. Oct 31, 2024 at 7:56 AM
    Retired...finally
    I might consider sending a sample of the ATF drained from your first D&F to a lab for their recommendations. I and many others here use Blackstone. Other labs probably just as good.
  7. Oct 31, 2024 at 8:07 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
  8. Oct 31, 2024 at 8:15 AM
    reddog4245
    Doug
    Kentucy
    2014 SR5 TUNDRA
    Copy that on testing.
    And I have seen some horror videos on broken pan bolts! Really didn't want to go there!
    Another question...what about other brands of fluid, besides Toyota, that are WS rated??
    Federated, etc?
    TheOverlander likes this.
  9. Oct 31, 2024 at 8:20 AM
    TheOverlander
    TheOverlander New Member
    Bobby
    Interested in that as well as changing diff and TC fluid. Coming up on 100k and need to do it. Probably going to swap spark plugs and steering
  10. Oct 31, 2024 at 8:25 AM
    Pr4sno
    Pr4sno New Member
    Loveland, CO
    Valvoline max life atf has worked well for me in several Toyotas over hundreds of thousands of miles. It's readily available, reasonably priced, and compatible.
    I have also used the AISIN WS fluid with similar results. I find it through rock auto.
  11. Oct 31, 2024 at 9:05 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I can confirm this, at 270K, I swapped mine out, it was relatively clean and could've been reused, but I decided to leave it out. It's in my garage in a plastic bag.
