High Mileage Towing
Discussion in '2nd Gen Tundras (2007-2013)' started by TXTundraFan, Sep 12, 2020.
  1. Sep 12, 2020 at 5:06 PM
    TXTundraFan
    TXTundraFan [OP] New Member
    I have a 2010 Tundra with 216k miles. I purchased it two months ago and it was a one owner vehicle with all maintenance done at the same dealership it was purchased from which is also where I bought it.
    Would you trust towing approx 4k pounds halfway across the country with that many miles on a Tundra? I just want to make sure if I do this that I shouldn't have to worry about anything.
  2. Sep 12, 2020 at 5:09 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I towed a 93 sc400 about 600 miles, thats probably a combined weight of 6k, should be fine... mine is an 07 5.7, 215k at the time, 222k now..
    Filthyphil and TXTundraFan[OP] like this.
  3. Sep 12, 2020 at 5:21 PM
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    Well, you probably didn't buy it just to look at it.
    Charge your phone, make sure your AAA card is up to date and in your wallet, hop in and GO!
    hhenry_, olds350, Filthyphil and 5 others like this.
  4. Sep 12, 2020 at 5:31 PM
    TXTundraFan
    I failed to mention, I have the 5.7L engine.
    There's a possibility of a cross country move and I would need to be able to tow one of our other vehicles if possible.
    AZBoatHauler likes this.
  5. Sep 12, 2020 at 5:41 PM
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    You’ll be fine. Strap it down and go!
    TXTundraFan[OP] likes this.
  6. Sep 12, 2020 at 5:57 PM
    Wouldn't even worry about it.
  7. Sep 12, 2020 at 6:23 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Wouldn't hesitate. Mine has more miles and I tow the same or more almost every weekend. Hell I supercharged mine at your mileage :D
    szabo101 and Filthyphil like this.
  8. Sep 12, 2020 at 6:28 PM
    Wsteven
    Wsteven New Member
    2007 White SR5 Single Cab
    It is a Toyota ....:drunk: go for it
  9. Sep 12, 2020 at 6:45 PM
    AZBoatHauler
    So.Arizona
    You’ll be fine. Maybe check the brake pads and fluid levels before you go. When was the last time the diff fluid was changed?
    Taco-Blender likes this.
  10. Sep 13, 2020 at 6:47 AM
    Jeffro22
    Jeffro22 New Member
    2013 platinum crewmax 4x4
    I have 250k on mine and plan to tow my boat about 1200 miles round trip once a year
    I regularly tow locally also
  11. Sep 13, 2020 at 7:09 AM
    timsp8
    NY
    My transmission went out in my 2010. While it was having issues, I pulled about 4000 lbs in a uhaul from mo to tx. I had to let it warm up before it would shift after stops, but made it.
    Filthyphil likes this.
  12. Sep 13, 2020 at 11:49 AM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    I'd worry more about the trailer. If it's your trailer, make sure you have good tires and bring spares and tools to change them. Also check and repack the bearings.
    Check the trailer tires and bearing caps for overheating when you stop for gas.
  13. Sep 13, 2020 at 1:34 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Stud
    FundraTRD likes this.
  14. Sep 14, 2020 at 2:16 PM
    Johnnyquad
    Johnnyquad New Member
    21 Pro double cab MGM
    Tint, clear bra, OEM stereo upgrade, tonneau cover, line x, 285/65/18 Toyo AT3
    How much did you get your Tundra for? I'm curious to see how well they hold their value with 200k plus miles on it. Drive safe and congratulations.
  15. Sep 14, 2020 at 2:20 PM
    Professional Hand Model
    Hand Protectors
    4k lbs and under you’ll be fine. Not sure of your fluid history, but a refresh might be nice before the journey.
  16. Sep 30, 2020 at 9:29 AM
    TXTundraFan
    $13K out the door with TTL. I think it was $11.7K before TTL. It was below NADA which is what my bank went off of so they were good with it.
  17. Oct 26, 2020 at 6:21 PM
    Kubeanie
    Kubeanie New Member
    2007 tundra 5.7 milwaukee mile pace truck
    My 2007 double cab 5.7 is worth 7 grand it's got $369,000 on it these things are shockingly valuable.
