High Mileage oil?
Discussion in '2nd Gen Tundras (2007-2013)' started by silverTRDragon321, Dec 21, 2022.
  1. Dec 21, 2022 at 11:11 AM
    silverTRDragon321
    silverTRDragon321 [OP] New Member
    2010 Tundra Double Cab 5.7 TRD
    My new-to-me 2010 5.7 4x4 has 276300 on it. It had a oil change before I bought it but unclear whether or not they used 0w20 or 5w20. I've had a few mechanics suggest switching to a heavier grade.
    Is something like a synthetic 5w30 or 10w30 a bad idea for this engine?
    Truck is in a cold weather state.
    Appreciate any recommendations, thanks -
  2. Dec 21, 2022 at 11:19 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Pennzoil 0w20 Full synth High mileage is what I have been running. With 5w20 swap in the summer.
    New plugs might be in order too if you don't know the replacement history?
    NGK V powers are good.
    silverTRDragon321[OP] likes this.
  3. Dec 21, 2022 at 11:25 AM
    silverTRDragon321
    Great to know, thanks!!
  4. Dec 21, 2022 at 1:00 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I think you can run any oil and any of the weights you suggested would be fine. People that have valvetrain noise usually run thicker oil, and some people argue the engine should run thicker since some foreign specs call for thicker and the thinner is just for emissions.
    Personally I'm at 282k and just run 0w-20 since that's what the thing says and change it every 5k. I wouldn't overthink it, hard to fuck up the oil on the 5.7.
  5. Dec 22, 2022 at 1:58 PM
    Jeffro22
    Jeffro22 New Member
    2013 platinum crewmax 4x4
    I have 280K on mine.
    Been on 5-20 or 0-20 almost its whole life @ 10K intervals. I wouldn't dump your oil until its ready for a change. I would stick with a 0-20 , 5-20 or 0-30 or 5-30
  6. Dec 22, 2022 at 7:02 PM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    Mine has around 280,000 on it and I run 5W-20 high mileage full synthetic. I am in Tennessee so it really doesn’t stay very cold here for very long. Change it every 5k.
  7. Dec 22, 2022 at 11:30 PM
    Sierramare’
    Sierramare’ New Member
    Ted
    Alaska
    2007 SR5 DC 4wd
  8. Dec 23, 2022 at 4:34 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    I'm running full-syn 5w30 in my '07 these days to eliminate valve train noise/ chatter. This last oil change I also added half a bottle of Seafoam to break up any buildup that may have accumulated over the years and a bottle of STP high mileage oil treatment. I bought mine used back in 2017. She has around 220k on her (I think).
  9. Dec 23, 2022 at 5:47 AM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    0w -20 in mine with 220k
  10. Dec 25, 2022 at 5:33 PM
    Jeffro22
    Jeffro22 New Member
    I would ditch the stp. No need for it and probably more likely to cause issues
  11. Dec 25, 2022 at 6:40 PM
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    I’ve used 0-30 and 5-30 for its whole life (220k). Burns zero. Leaks zero. Was spotless under valve covers when i replaced a spark plug tube gasket a few months ago.
    I think its more important you’re staying on schedule with oil/filter changes than the weight…20 or 30 weight always hold up well in these things. If you tow, stop/go/idle a lot or live in heat, I’d lean towards the 30w oils.
    Not a fan of 10k mile oil changes so I'm pretty religious around the 5k mile mark, although I’ve drug it out to 7500 a few times.
  12. Dec 27, 2022 at 4:15 AM
    BlueCrushSC16
    Charleston, SC
    Based on what? There may be no need for it, but it's no different than if I had used oil for "high mileage" vehicles. Most reviews on the product are positive.
  13. Dec 27, 2022 at 10:30 AM
    Jeffro22
    Jeffro22 New Member
    If you want to run a thicker oil why not use a 0w-30 or even a 0w-40 or 5w-40. That way it’s engineered with correct additives. Oils today are really good and shouldn’t need any extra additives, and will go easily for 10k OCI
    that stp syrup could cause any number of issues including sludge buildup, additive clash, et.
    It may be fine , but I just don’t see the need for risking it.
    Mike59 and silverTRDragon321[OP] like this.
  14. Dec 27, 2022 at 10:58 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Good point.
    I never add anything to my oil.
    If I wanted more additives, I would switch to brands that have the applicable additive pkg, ex. more moly.
    Presently still running Kirkland 0w-20 / 5w-30.
    Oil analysis has told me the oil is wearing ~5k. yes it's still good, but it's wearing. So I change at 5k.
    If life gets in the way - I can run it longer and not worry.
    I run daughter's '18 Highlander to 7500. That car is easy on oil.
    Same for the son's '15 4runner.
    none of our Toyotas burn oil. none.
    the '06 Sequoia never burned oil.
    so, don't focus on the mileage - focus on if you are burning oil & making sure you stay full.
  15. Dec 27, 2022 at 10:52 PM
    Dank
    Dank New Member
    2010 Black Tundra 4wd
    That Seafoam sure works! Had the warmup clatter from the timing chain tensioner. No more after using it in the oil!
    Been running Toyota 0w-20 synthetic. Works well but damn is that stuff expensive now! Costco synthetic oil caught my eye the other day. Don’t know how good that stuff is. Around $3 or $4 per quart if you buy ten of them.
  16. Dec 28, 2022 at 3:31 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Kirkland oil proved itself to me. I've mentioned on other threads i used it during my S/C install & the associated dyno runs (~18 of them). had a Blackstone done after another 4000 miles after install & the oil performed damn well. I've used it since the 1st oil change on my '20 Tundra.
    Project Farm youtube channel does a nice video on it.
    engines don't fail if they have oil in them...near any oil. just keep it oily. any oil will do.
  17. Dec 28, 2022 at 3:35 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
  18. Dec 28, 2022 at 4:17 AM
    Mike59
    Mike59 Kentucky Traveller
    Central Kentucky
    2021 Tundra DC Limited 4x4 SSM
    And we'll be lucky to live through it!
    lol
  19. Dec 28, 2022 at 5:38 AM
    Dank
    Dank New Member
    Thanks NobodyinTexas! Good to know for when I by oil again. Bought a sh!t load of it before the price went up over $3/qt. Project Farm is the best!!!
    WILLINH and Mike59 like this.
  20. Jan 18, 2023 at 10:13 PM
    Skywind
    Skywind New Member
    Hello everyone, I switched to 5w30 Mobile One full synthetic from 0W20 Pennzoil Platinum and am happy with the lower valve train noise especially at highway speeds! Anyone run 10w30?
  21. Jan 19, 2023 at 4:11 AM
    Jeffro22
    Jeffro22 New Member
    There really wouldn’t be any reason or benefit to run 10w-30.
    the 0w-30 or a 5-30 is a good choice. I would even be tempted to run a 0-40 euro oil or rotella if wanting a thicker oil
