High mileage issues
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mikegillam, Aug 11, 2019.
  1. Aug 11, 2019 at 8:00 AM
    Mikegillam
    Mikegillam [OP] New Member
    i have a 2014 tundra TRD with 180k miles. With plans to make multiple trips from Ohio westward (Colorado, Arizona, California) I am trying to decide whether I should trade or keep. Up to this point, no mechanical issues. Planning on coolant and transmission drain and fill before my Sept. trip to Arizona. What issues are you seeing with higher mileage tundras with 5.7? Obviously, no truck payments are nice, but....
    T-Rex266 likes this.
  2. Aug 11, 2019 at 8:08 AM
    Adam New Member
    Cam tower leak will hit any mileage tundra, so you can check that one out. Your choice as to if you want to get it fixed. I would have let mine ride had it not been under warranty. Have you serviced the differentials? Are you going to be towing anything? You going elk hunting?
    Black Wolf, panicman and Max Power like this.
  3. Aug 11, 2019 at 8:11 AM
    Devcom
    Devcom Miles per Gallon? More like Smiles per Gallon!!
    2018 Blazing Blue Tundra Double Cab SR5 5.7L 4x4
    Only thing I can think of based on what I read is the Cam tower leak but that you can just let go. Most of the time from what I seen picture wise and heard from others is that is it is a seap and you wont notice a loss of oil during the oil change intervals.
    TheBeast likes this.
  4. Aug 11, 2019 at 9:22 AM
    Mikegillam
    Not towing anything. Daughter in Flagstaff, sister in San Diego, kayaking, ice climbing & skiing in Colorado (and NH, NY). Put in for elk once, no luck, although I may look at going out for an otc tag...diffs we’re done.
    Black Wolf likes this.
  5. Aug 11, 2019 at 10:20 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    To be honest I wouldn't worry at all.
    It sounds like you drive the truck regularly enough that you know it's quirks. Trust your gut.
    These trucks see high mileage all the time so we know they're proven machines.
    Tires good?
    If it were me I would simply make sure you have a good set of tools with you in case you need it.
    Probably only need a handful of tools to swap an alternator...
    jewsNbrews likes this.
  6. Aug 11, 2019 at 10:47 AM
    Max Power
    Max Power Groovy Member
    2018 SR5 TRD Off Road
    TRD Dual Exhaust TRD Rear Sway Bar
    It's especially important when you go elk hunting to avoid mailboxes.
  7. Aug 11, 2019 at 11:26 AM
    Adam New Member
  8. Aug 11, 2019 at 11:35 AM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    If the wife lets you..... Buy a new 1794,, light the biggest stinkiest cigar you can find,, go for a long drive and enjoy!!!
  9. Aug 11, 2019 at 11:38 AM
    TheBeast The Beach
    check brake pads, rotors, tires, spark plugs, air filter..the usual. If you don't have any issues, keep on truckin. Paid off truck is the best :)
  10. Aug 11, 2019 at 11:50 AM
    Racingjohndeere55
    Racingjohndeere55 New Member
    Run it till the body falls off. Make sure the radio plays loud enough to cover any suspicious noises
    jewsNbrews and Black Wolf like this.
  11. Aug 11, 2019 at 1:55 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    The thing about Toyotas is that you can have peace of mind with high miles. You just gotta stay on your maintenance schedule.
    Once I hit 100k on my 4Runner, I started doing trans service every 20k. I’m looking at replacing the serpentine belt and maybe the alternator and water pump just to do them all at the same time. I’ve done gear oil in both axles and the transfer case, and I regularly lube the driveshaft joints, UCAs (aftermarket), and poly sway bar bushings (aftermarket as well). There’s a lot more to think about than just motor oil and brakes. But I enjoy doing all that myself and the peace of mind that comes with it.
  12. Aug 11, 2019 at 2:09 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    :rofl::rofl::rofl:
  13. Aug 11, 2019 at 2:26 PM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    The elk hunter is reading every word of this....
    Black Wolf, Ericsopa and Leo's first like this.
  14. Aug 11, 2019 at 3:16 PM
    You win the internet today sir.
  15. Aug 11, 2019 at 5:58 PM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    Just drive the damn thing...
  16. Aug 11, 2019 at 6:02 PM
  17. Aug 11, 2019 at 6:55 PM
    CyberViking
    CyberViking New Member
    The Ozarks
    2018 MGM Tundra TRD Sport
    Around that mileage I've seen some starters going out on forum member trucks. I doubt it's common, just something I've noticed....and it's not something you're gonna fix in 1 hr like you can on the big 3 trucks. I'd keep the truck..just keep up with maintenance.
    Edit: Usually closer to and slightly beyond 200k miles so you have awhile.
    Black Wolf and Mikegillam[OP] like this.
  18. Aug 12, 2019 at 5:56 PM
    Devildog183
    Devildog183 New Member
    Roger
    Kansas
    2019 Limited CM 4x4 2007 SR5 DC 4x4
    I still have my 07 I bought new, it has 375000 miles on it and I’d jump in it and go no worries. But I am enjoying my 2019 crew max I just got! Go and don’t worry! Have a good trip.
    Larly5000 and Black Wolf like this.
  19. Aug 12, 2019 at 7:22 PM
    zerosyche
    zerosyche New Member
    Alberta
    14 Silver Tundra SR5 CM Off-Road
    This is exactly the stuff I like reading about !
