High Mileage FFV in Cold Climates
Discussion in '2.5 Gen Tundras (2014-2021)' started by JEM1891, Nov 19, 2024.
  1. Nov 19, 2024 at 5:40 AM
    JEM1891
    JEM1891 [OP] New Member
    Jake
    Fort Kent, ME
    2016 Black 1794 FFV
    Hey yall,
    Just wondering how many people here have high milages FFV motors in cold climates with no issues?
    I just brought my FFV with 64k miles up to Northern Maine so I will update as well after this winter. We are destined to see plenty of negative days so we'll see how it goes!
  2. Nov 19, 2024 at 8:09 AM
    kbahus
    kbahus New Member
    MI
    2015 MGM Tundra Limited Crewmax
    Not as cold as Maine, but no weather related issues in Michigan with mine so far. 205k, I did replace the fuel pump last year.
    rodm1 likes this.
  3. Nov 19, 2024 at 8:40 AM
    JEM1891
    Jake
    Fort Kent, ME
    2016 Black 1794 FFV
    Good to hear! Have you ever run E85?
  4. Nov 19, 2024 at 9:38 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    I bought my 2012 a little over 2 1/2 years ago with 63k miles. When I stumbled on this forum around that time I learned of ffv issues with hard starting in colder climates. I was mad at myself for not knowing this and waiting for a non ffv. However, it seems that not all ffv vehicle's have this problem consistently as I haven't had any issue as of yet. I did buy the xtool ds7 to be able to reset alcohol percentages but haven't had to use it yet. It's a great tool to have for the peace of mind if you're concerned.
    https://www.xtoolglobal.com/collect...wifi-connection-with-ecu-coding-obd-2-scanner
    Amazon has them available as well but I bought mine direct.
    lastly, I personally wouldn't consider your truck high mileage...
  5. Nov 19, 2024 at 9:58 AM
    kbahus
    kbahus New Member
    MI
    No E85 for me!
    rodm1 and OldGuy03 like this.
  6. Nov 19, 2024 at 10:03 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    My .02 cents, just don't.
    rodm1, Tunrod and dt325ic like this.
  7. Nov 19, 2024 at 10:06 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Yes, this is the way to go.
    At the bare minimum, get an inexpensive code reader so that you can check the fuel alcohol percentage regularly. If it starts creeping up past 30% or so, I would then look for a reader (such as below) or a shop that could reset it for you. You want to prevent the fuel pump from going into E85 mode. It can happen whether you use E85 or not. If you do this, the fuel pump should not burn out early.
    OldGuy03[QUOTED] likes this.
  8. Nov 19, 2024 at 1:56 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
  9. Nov 25, 2024 at 3:26 AM
    JEM1891
    Jake
    Fort Kent, ME
    2016 Black 1794 FFV
    Oh, I don't consider my truck high mileage at all! I have a 1996 4runner with 204k and a 2005 Corolla with 290k right now and I don't even consider those high mileage yet!
    I was just wondering if there were some people into the higher mileages living in super cold climates with no issues. We can see -15 or colder up here in the middle of winter.
    Thanks for the replies yall!
