High beams work on hold, but not on toggle?
Discussion in '2.5 Gen Tundras (2014-2021)' started by TundyFromDownUndy, Sep 23, 2022.
  1. Sep 23, 2022 at 9:18 PM
    TundyFromDownUndy
    TundyFromDownUndy [OP] New Member
    2020 Platinum Tundra
    My trucks high beams don't work when I flip my brights on (no dash light either) , but if I pull and hold the stick towards me, they come on... and when I let go, as designed, they go back off. I haven't had any long trips since buying the truck, so didn't notice until a week or so ago, so its been like this since I bought it. Anyone have any ideas? Scheduled to go in the 13th of October.
  2. Sep 23, 2022 at 9:20 PM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    Have you tried to push the stick? Mine works by pushing it
    FlyingWolfe likes this.
  3. Sep 23, 2022 at 9:24 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 OR MGM 5.7
    Did you check the automatic high beams switch position?
  4. Sep 23, 2022 at 10:12 PM
    TundyFromDownUndy
    Um, I didn't know that was even a thing. I swear everyday I discover something new.
    GODZILLA, EDDO[QUOTED] and MT Madman like this.
  5. Sep 24, 2022 at 5:17 AM
    Coastboater
    Coastboater New Member
    Wheels & Tires, Power Running Boards
    this
    Tundra'25, panicman and EDDO[QUOTED] like this.
  6. Sep 24, 2022 at 7:14 PM
    TundyFromDownUndy
    Actually that wasn't it. I went out, clicked it in, tried and nothing, then clicked it out. It wasn't on to begin with. BUT, there's a little skinny dial, and I figured it was for dimming the dash lights. But it adjusts the headlight position. They were all the way up. The truck must not let you use constant brights with your headlights at max height. Kinda neat. I lowered them and the brights work again
  7. Sep 24, 2022 at 7:32 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I have a 2019 platinum and my dial is always in the 0 position (all the way up) you should only need to point them down if you are hauling something causing you to sag in the rear. I can turn my high beams on no problem, unless of course the auto high beam is on, then they wont come on unless there is no oncoming traffic. Also due to high safety laws you can not have more than X amount of forward facing lights so if your fogs are on when you turn on the highs, the fogs will shut off.
  8. Sep 25, 2022 at 11:41 AM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Hmmm… I’m going to have to try.
    I think I have my headlights all the way up or maybe down one click. Only control inhibition is when the auto feature is in use.
  9. Sep 25, 2022 at 12:06 PM
    Retired...finally
    Makes sense. One wouldn't want aircraft making approaches to land right in front of you.
  10. Sep 25, 2022 at 1:33 PM
    Joe333x
    Joe333x Member
    Boston
    Are you doing this with the lights in the auto position by chance?
  11. Sep 26, 2022 at 5:46 AM
    Coastboater
    My wife was asking me if I was crazy last night sitting in the driveway fiddling with my newly discovered headlight/wheel thingy!
    Retired...finally likes this.
  12. Sep 26, 2022 at 11:16 AM
    TundyFromDownUndy
    Nope they only work when in non auto position
  13. Sep 26, 2022 at 11:16 AM
    TundyFromDownUndy
    That was me the past 2 nights too, neat as f
  14. Oct 17, 2022 at 6:20 PM
    Buck1x
    Buck1x New Member
    2002 Tundra SR5
    Can we divert slightly to a 2002 Tundra? I have no high beams at all when I pull the stick back OR when it is forward in the High Beam position. I have replaced the relay and checked the fuses. Thinking it was the bulbs, I replaced them both with Plug and Play LED Sylvania's which the factory assured me is a plug and play headlight bulb for both bright and dims. They have a box connected to each bulb and no additional resistor is needed. I do not have flasher issues. I am told that I have a very slight illumination at the bulb when I pull the stick to me but have not seen that for myself. Taking it across country Wednesday and the brights would be helpful.
  15. Oct 17, 2022 at 7:41 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Sounds like you're experiencing a need for a new headlight stalk... how're your headlight bulb harnesses? Nothing burnt, right?
  16. Oct 18, 2022 at 3:49 AM
    Cody1060
    Cody1060 New Member
    Ken
    Mid Michigan
    2021 Tundra 1794
    My wife asks me this question all the time... and I'm starting to think she's spot on.:yes:
  17. Oct 18, 2022 at 10:04 AM
    Buck1x
    Buck1x New Member
    2002 Tundra SR5
    HulkSmurf14: I checked and on the brights I am getting a very dim flickering. I heard that on later models the fog lights interacted with the brights so I checked out all the switches and gadgets in the dash. One button looks like the fog lamp switch but in or out there was no change in anything. I have no fog lamps shining either. I then pulled the fog lamps and tried the lights without the bulbs. No change. I will take another look at that switch. So far I have found no burnt or compressed wires and the harnesses have looked flexible and clean. The fog lamps are looking enticing.
    HulkSmurf14 likes this.
  18. Oct 18, 2022 at 10:17 AM
    HulkSmurf14
    2014 Tundra Limited
    Hmmm, try this: it suggests a faulty headlight switch...https://www.yourmechanic.com/article/symptoms-of-a-bad-or-failing-headlight-switch
    Another option is to wire in an upgraded headlight harness that still uses your headlight stalk switch but you get power directly from the battery and relay and improves the halogen light output 100% roughly...https://www.amazon.com/Negative-Swi...t=&hvlocphy=9021322&hvtargid=pla-623164023496
  19. Aug 17, 2023 at 7:04 PM
    Jerisito
    Jerisito New Member
    Luis
    Here is a crazy one maybe someone can help 2007 tundra driver window wont work fog lights always on i can turn them one by pushing forward then back but if i open doors their on again no headlights work unless i pull back for high beams and when i pull back for high beams the passenger windows work dome lights for door open work i let go nothing works ive checked all wireing and all seems fine ive switch master window switch but driver window dont work i tried directly and motor works i need help on this one
