Hidden winch mount
Discussion in 'Recovery & Gear' started by cadis10, Mar 19, 2015.
  1. Mar 19, 2015 at 5:14 AM
    cadis10
    cadis10 [OP] New Member
    2011 CREWMAX TRD
    TRD exhaust, 3" lift 33" and 22's
    Anyone have one installed on the front of there tundra? Im thinking of mocking one up this summer.
  2. Mar 20, 2015 at 12:48 AM
    Rkcruza
    Rkcruza New Member
    Bob
    2002 Tundra AC 4WD TRD OR SR5
    De Badged / Decaled, Firestone Ride Rite Air Bags w/ Daystar Cups, 17" Rims, Big Brake kit w/ slotted & drilled rotors, plus lots of work related stuff.
    Looked all over for one for my 1st Gen and couldn't find one (I had won a winch and was going to put it on)...not sure about availability for the newer Tundras.
  3. Mar 20, 2015 at 1:29 AM
    andrew
    andrew where's the beer?
    andrew
    2012 rockwarrior
    stock
    you find one, let us know man! that would of saved me quite the headache a few months ago.
  4. Mar 20, 2015 at 2:53 PM
    cadis10
    2011 CREWMAX TRD
    There are 2 companys that are in the process of making them but im starting to think im goiing to pull my front end apart and mock up one soon
  5. Mar 21, 2017 at 4:57 PM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    I have the SDHQ hidden winch mount on my 2015.. I modified it slightly to allow for use of the Harbor Freight 12,000lb winch the entire install cost just under $1000. Not a bad mod and I am happy with the results.
  6. Mar 21, 2017 at 5:10 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    The SDHQ mount is on my list.
    Sonicbluerider and sdhq_offroad like this.
  7. Mar 21, 2017 at 8:08 PM
    Dcuff
    Dcuff New Member
    Dave
    Outside of Philadelphia
    Silver. Tun 4x4 doublecab SR5
    Bull bar, spot light and fog lights. Master lock tool lock system. Rear brake lights underneath the Tellgate with turn signal's, just added new step bars, vent visors, HID head lights and fog lights. Just ordered a lift kit.
    Is that from Harbor freight
  8. Mar 22, 2017 at 6:39 PM
    Vector W8
    The 12,000lb winch is. It has come in handy a dozen times pulling friends out of some deep mud. I have never had a problem with it. For the number of times I have used it for the deep discount price of $279.00 on sale. Its a tough winch to beat. I have not submerged it under water, but it has been used quite a bit without any issues.
    NewImprovedRon likes this.
  9. Mar 25, 2017 at 8:13 AM
    Dcuff
    Dcuff New Member
    Dave
    I've always wondered about them. I was a bit sketchy on buying one thanks for the heads up.
  10. Mar 25, 2017 at 1:51 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    There's at least 3 shops fabricating these for gen 3's. I have the SDHQ also.IMG_0178.jpgIMG_0179.jpg
  11. Mar 26, 2017 at 2:23 PM
    Vector W8
    Had to relocate the controls box, and then drill different mounting holes, then need longer screws to mount it to the steel. The front bumper lower grill needed trimming out so you could get your hand in to access the winch lever and then slight dremmeling to allow the cable guide levers to clear the lower grill. Just little things.
    kenomouth64 and NewImprovedRon like this.
  12. Aug 8, 2017 at 7:50 PM
    pamtnman
    pamtnman New Member
    God's Country
    '17 Tundra TRD CrewMax
    Working through the list
    After doing as much research as I could without jumping off the back porch, the SDHQ hidden winch mount is next up on the steadily descreasing list of upgrades to the new '17 Tundra here. It looks like a high quality product. Using the Warn 8000 Lb winch, however, instead of the Zeon the mount is designed to hold. The Zeon is three times the money and twice the winch I will likely ever need. Thanks to SDHQ for investing the time and effort to bring us something this nice. Understatement is my thing. This is it.
  13. Jan 18, 2018 at 10:20 AM
    wc4wd
    wc4wd New Member
    2018 SR5 4x4
    Pamtman
    It looks like you went with the m8000 by my read of your post. Have you installed and did it go well (what mods for the m8000, how do you access clutch, etc)? I’ve got an m8000 and was looking at this mount over a heavy bumper
    pamtnman[QUOTED] likes this.
  14. Jan 18, 2018 at 10:34 AM
    pamtnman
    pamtnman New Member
    God's Country
    Hey buddy. Glad you are researching it. The Fall arrived and I ran out of time to get my truck off the road. This spring I'll put on the SDHQ bumper and a heavier winch. Probably 10,000 lbs. I'm unconvinced the wireless is better. Too many things can go wrong. I like hands-on, manual, etc keep it simple.
    wc4wd[QUOTED] likes this.
  15. Jan 18, 2018 at 10:41 AM
    wc4wd
    wc4wd New Member
    2018 SR5 4x4
    Nice. I’ll probably be looking to begin my install around then as well. Updates all around in the spring
  16. Jan 20, 2018 at 4:23 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    pamtnman likes this.
  17. Feb 13, 2018 at 9:27 AM
    pamtnman
    pamtnman New Member
    God's Country
    Got the File Not Found 404 response...but I will look around
  18. Feb 14, 2018 at 7:23 AM
    01erionracing
    01erionracing KJ6RKU
    Jimmy
    2000 SR5 4WD 2002 SR5 4wd 2008 CM Limited 4wd
    Nice looking winch mount.
  19. Oct 30, 2018 at 8:13 PM
    saramos
    saramos New Member
    Scott
    2014 Tundra
    Bilstien 6112s 2" rear shackles. LED headlights. Interior wood trim. 798Addict Wheels. Nitto Ridge Grapplers. Tonnaeu Cover, Fenders, Side Steps. 4 camera system
    The SDHQ is on my wish list too.
  20. Feb 5, 2019 at 2:50 PM
    Joe Dirt
    Joe Dirt New Member
    Don
    Sunriver, Oregun
    Silver 2018 SR5 4X4 DC
    My 2013 and 12k hidden winch with wireless controls.
    Sonicbluerider and Gungho like this.
  21. Aug 15, 2019 at 11:46 AM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
  22. Oct 9, 2019 at 3:53 PM
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    putting on a sdhq hidden bumper as i write this and a wern winch
    theraven likes this.
  23. Oct 9, 2019 at 5:46 PM
    Zero One Actual
    pics
  24. Oct 9, 2019 at 6:09 PM
    Sonicbluerider
    Dennis
    2019 Tundra
    when I get the truck back will do!!!!!
    Zero One Actual likes this.
  25. Oct 10, 2019 at 2:15 PM
    Sonicbluerider
    Dennis
    2019 Tundra
  26. Oct 10, 2019 at 2:51 PM
    Civiceg94
    Civiceg94 New Member
    NYC
    2007 Toyota Tundra Crewmax 5.7 Limited
    Horn baffle delete Fox 2.5 DSC Setup DAP TUNED RW WHEELS 285/75/17 AT3 LTX
    5CE1AAC3-DBD9-41F2-9F15-B1A29112D259.jpg F3F56B8D-4AB0-4812-84D2-416684AF5F2F.jpg Made my own hidden winch setup. One wont know its there if your not looking for it. Cheap strong. Not something ill be using most likely. So i didnt want to spend hundreds or thousands on a bumper or hidden winch setup that still showed their was something there.
  27. Nov 14, 2019 at 6:38 PM
    Spoolnms
    Spoolnms New Member
    Ryan
    2014 Tundra
    7" lift, 37x13.50r18, catback dual exhaust, intake, etc.
    Anymore pics? Was looking to make myself one (big DIY guy) and was looking to make one for my 2014.
  28. Nov 14, 2019 at 7:08 PM
    Civiceg94
    NYC
    Nope. Just those pictures. Was to busy making it lol. Same frame from 2007-present
  29. Nov 15, 2019 at 5:13 AM
    Spoolnms
    Spoolnms New Member
    Ryan
    2014 Tundra
    Ah. I just got my cnc plasma up and running, time to model and cut then!
  30. Nov 15, 2019 at 5:18 AM
    Civiceg94
    NYC
    I used a universal harbor freight winch plate and some angled metal and started hacking away to make it fit on the truck and behind the bumper
