HID issue, won't always turn on
Discussion in 'Lighting' started by HBdirtbag, Feb 15, 2019.
  1. Feb 15, 2019 at 11:51 AM
    HBdirtbag
    HBdirtbag [OP] New Member
    Walnut Creek, CA
    2017 limited cm
    Have a retrofit set of lights on for a few years now. Haven't had issue. I had originally cut the DRL switchback wire, and reconnected it a few weeks ago. Since, i've been noticing a problem.
    If my headlights are on, and i manually turn them off, they then won't turn back on unless I turn the car off, and restart it. All other lights work fine (LED strip, parking light, etc). When I turn the lights back on and they dont fire, the switch back operates properly.
    (For the record, i've checked all wiring, haven't found anything. And I think the use case of when the lights are on, and i shut off, and then won't turn back on is the right scenario, but it didn't dawn on me till last night).
    This may be total stoner gibberish above
  2. Feb 15, 2019 at 12:22 PM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    Both or just one?
  3. Feb 15, 2019 at 12:28 PM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
  4. Feb 15, 2019 at 12:58 PM
    tomsinamerica
    Tom
    Wilmington, NC
    rules out ballast & grounds then? Relay? Have you tried disconnecting the switchback..
    i have a spare relay if you want to try it out?
  5. Feb 15, 2019 at 1:18 PM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    That's next step, disconnect switch back. It was such a royal pain in the ass to get reconnected i'm hesitant lol
  6. Feb 15, 2019 at 1:40 PM
    tomsinamerica
    Tom
    Wilmington, NC
    sent a PM - but I'd also triple check grounds if there's the slightest chance you disturbed them when you were reconnecting the SBs. Can't express in words quite how sensitive these are to stupidly clean grounding.
  7. Feb 15, 2019 at 3:57 PM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    Yea. I’m gonna go through all the wiring under the hood this weekend. Have wondered if maybe that’s it. I off road a lot so it gets very dirty and things bounce around a bit.
    I went out to test my theory today. Of course. Everything worked fine
  8. Feb 22, 2019 at 2:42 PM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    so, things had worked fine for a few days. Today i noticed passenger headlight wouldn't work. Found a lose ground wire. Recrimped the wire and bolted it back down....while doing that, there was a small spark. Thought nothing of it. Now neither don't work.
    I went and ordered a new relay https://www.amazon.com/Morimoto-Bi-...last&qid=1550875250&s=gateway&sr=8-4-fkmrnull
    @tomsinamerica appreciate the offer, figure ordering a new relay Amazon prime was the fastest route for me.
  9. Feb 22, 2019 at 2:45 PM
    Headlight Revolution
    Headlight Revolution New Member Vendor
    Atlanta, GA
    Check your Fuses?
  10. Feb 22, 2019 at 2:58 PM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    Checked all fuses. They were good. You made me go double check. All good.
    But guess what. Headlights fucking working fine........
  11. Feb 22, 2019 at 2:59 PM
    Atlanta, GA
    Gotta love it! :rofl::facepalm:
    HBdirtbag[QUOTED][OP] likes this.
  12. Feb 22, 2019 at 3:02 PM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    Well. I lied. They fired up. But when I toggle them on and off. They don’t go back on.
    And won’t go back on.
  13. Feb 22, 2019 at 3:04 PM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    Is there a resting period for these things I’ve never been aware of?
  14. Feb 22, 2019 at 3:15 PM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    We spoke too soon
  15. Aug 2, 2021 at 12:52 PM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    So, this problem is back for me. Low beams just won't turn on. High beams work fine. Sometimes if i leave the high beams on for a bit, the low beams will start working. When you do turn the high beams off, the low beams stay on for about .25-.5 seconds.
    I have no idea what I did to fix them last go around.
    Headlight Revolution likes this.
  16. Aug 2, 2021 at 1:46 PM
    Atlanta, GA
    Mind shooting us an email on this one with some specifics on your issues, as well as possibly some photos of your kit you're running? Our CS team would be happy to help you troubleshoot them, even if they aren't ours! :)
    Sales@HeadlightRevolution.com
  17. Aug 2, 2021 at 1:52 PM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    well that's fucking rad. You just won a customer when I need something! Email coming
  18. Aug 2, 2021 at 2:00 PM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
