Hi new memeber here.
Discussion in 'New Member Introductions' started by 2015 TUNDRA LIMITED, Mar 10, 2015.
  1. Mar 10, 2015 at 12:48 PM
    2015 TUNDRA LIMITED
    2015 TUNDRA LIMITED [OP] New Member
    2015 TUNDR LIMITED TRD
    New 6" Rough Country suspension lift kit
    I was wonder on tire size for my 2015 Tundra limited TRD 4x4.
    I bought new 18" rim's +10 and a front 2" level kit.
    could i put on 33" or 35"x12.50"x18" tires without rubbing?
    T-Rex266 likes this.
  2. Mar 10, 2015 at 1:27 PM
    FunkinTundra
    FunkinTundra New Member
    Cody
    2012 Tundra 5.7 CM
    OME614 full suspension\ Ekstrom design 3" shackles and poly bushing kit\ 295/70r18 Toyo MTs/ +20 offset Fuel Anzas\ 8" BAmuffler....etc...
    Welcome! With that set up you'd be rubbin pretty good with the 35s. You still may rub with the 33s too but not nearly as bad. Just gotta keep an eye on your offset...that is where you get into issues with your body mount. :)
    Bob likes this.
  3. Mar 10, 2015 at 2:58 PM
    Welcome! I would do a CMC if you're running 33"
  4. Mar 10, 2015 at 3:27 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Welcome from Obx
  5. Mar 10, 2015 at 8:07 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    welcome from PA! I like the rig!
  6. Mar 10, 2015 at 9:20 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Welcome. Stick with 33 with a 2" front level kit.
  7. Mar 11, 2015 at 3:05 AM
    chphilo
    chphilo Tundra addict
    Western PA
    Welcome. That's fairly aggressive offset. Definitely, you do not want to go with 35s, unless cutting stuff gives you pleasure. I have 18 mm offset wheels with 295's on and am very close to the body mount. Any wider tires, I would definitely be rubbing. But every truck is slightly different, so you may be okay (mine seems to be pushed out more than the other trucks I've seen). But don't go too wide.
