Hi lift jack alternative?
Discussion in 'Recovery & Gear' started by Zero One Actual, May 30, 2019.
  1. May 30, 2019 at 4:30 PM
    Zero One Actual
    Zero One Actual [OP] Member among Members
    I am going to 285/75R18 tires on 18 inch wheels. Truck will have Bilstein 6112 on top setting up front and coachbuilder +3 shackles in the rear to level it out.
    I don’t need or want a hi lift jack for every day driving. So I am wondering what is out there that can replace the stock toyota jack and that can be carried daily? I have a decked system in the back and a Leitner designs cargo system and under seat storage cut out under crewmax back seat also. Maybe the stock Jack is still good enough for my lift and new tires. I can always test it out in the driveway.
    Thanks for any suggestions.
  2. May 30, 2019 at 4:44 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    I don't think the stock jack is gonna cut it. You could look for bottle jacks with an extended reach. They're small enough to stow and can get the truck in the air much quicker than the stock one.
  3. May 30, 2019 at 4:47 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I have a one foot section of railroad tie in the bed of my truck. The OEM jack goes on top of it to compensate for lift.
  4. May 30, 2019 at 5:08 PM
    sdde4n
    sdde4n New Member
    People's Republic of California
    2018 CrewMax - Sierra Romeo Cinco
    Heavy, unnecessary offroad stuff.
    One of the "silverbacks" will have to elaborate, but my understanding is that a Hi-Lift and stock jack are used for different purposes. While you can use a hi-lift to change a tire, it's not ideal since it lifts the body of the vehicle and has to "outreach" the suspension's travel before getting the tire off the ground. Bottle jacks can be placed under the frame in a way that's more efficient than lifting from the slider or bumper (i.e., hi-lift). From what I've seen, Pro-Eagle can do both for a mere $500. :eek2:
    Sunnier likes this.
  5. May 30, 2019 at 5:10 PM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    I carry an 8 ton bottle jack. Small, compact, cheap, and works like a charm. Carry some kind of base-plate too in case you're in the dirt/sand/etc in the shoulder or off-road.
    TampaRD Pro and equin like this.
  6. May 30, 2019 at 5:52 PM
    Zero One Actual
    https://safejacks.com/
    This company seems to have some good kits already put together as well as some bases for off-road use. I’m going to give them a call tomorrow. Maybe even ask about a group buy.
    TreeCat, Sunnier and Opus5150 like this.
  7. May 30, 2019 at 6:01 PM
    RBDTx
    RBDTx New Member
    2019 Tundra TRD Pro White
    HiLift is not intended for changing tires. It is for odd stuff, like breaking a frozen wheel off the studs/wheel mount when nothing else works a mile from camp (main reason 1) or lifting the vehicle off a rock to the side, or pulling t posts out of the ground or winching the vehicle if nothing else works. I am not a serious off reader but my twin brother of a different mother can tell you that my HiLift got his truck home when nothing else could.
    sdde4n likes this.
  8. May 30, 2019 at 6:02 PM
    Professional Hand Model
    Hand Protectors
    Two or three small blocks of 2x6 cut just bigger than the base of the jack works well. Stack them as needed. Fits in the compartment, too. Win win.
    USCG2005, equin and Darkness like this.
  9. May 30, 2019 at 6:08 PM
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
  10. May 30, 2019 at 7:23 PM
    Opus5150
    Opus5150 Terminal Lance
    Live Free or Die
    2017 Tundra
    Keep us posted on the possible group buy @Zero One Actual. I'd be interested if that took off.
    Zero One Actual[OP] likes this.
  11. Jun 3, 2019 at 6:47 PM
    ricsha
    ricsha One is none, two is one.
    Rich
    Oregon Coast
    2019 Tundra Limited TRD
    I’ve recently purchased 2 of the SafeJack kits and am impressed with them. I’ve always had HiLift jacks, but my new Tundra like most new trucks lacks suitable jacking points. A bottle jack, any suitable bottle jack, with the SafeJack extensions seems to be a great way to go. A base, or bases, would be a must-have accessory. A handle extension is also on my list to keep from lying under the truck while using the jack.
  12. Jun 3, 2019 at 7:46 PM
    TundraDude18
    TundraDude18 Deus vult
    'Merica
    '21 Limited CM
    Silver Bullet Express
    Carried one of these forever when I was young ... zip, zip, zip and up it goes!
    Had a smaller floor jack I carried for a while too ... dropped it on my big toe when I was wearing sandals once: said "son of a buck" about 8 times [that was when I was a better person and didn't cuss as much]; after about 2 minutes, when the pain wasn't receding AT ALL, I started praying.
    I was carrying it by the 'twist-on' handle like a total dumbass.
    Sunnier likes this.
  13. Jun 3, 2019 at 10:29 PM
    TheFreshMouse
    TheFreshMouse learning as i go...
    Mouse
    18 CM MGM
    Pinstripes
    this is what i have too. works great for higher clearance stuff. also the only jack that reaches my tahoe's frame...
    cheaper at tractor supply-
    https://www.tractorsupply.com/tsc/product/powerbuilt-3-ton-all-in-one-jack
  14. Jun 3, 2019 at 11:08 PM
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    Sunnier likes this.
  15. Jun 3, 2019 at 11:10 PM
    TheFreshMouse
    Mouse
    18 CM MGM
    Pinstripes
    yeah i was thinking same thing... seems like it was in the 30s when i bought too...
  16. Apr 28, 2021 at 10:19 AM
    Damie Street
    Damie Street New Member
    Edsel
    South Carolina
    2016 MGM CrewMax SR5 TRD OffRoad
    Did you end up purchasing the Safe Jack?
  17. Apr 28, 2021 at 10:22 AM
    msmmce1
    msmmce1 New Member
    Hummer H1 surplus scissor jack with agile offroad adapter. 3.5 ton capacity, packaged neatly
    ColoradoTJ likes this.
  18. Apr 28, 2021 at 10:30 AM
    Damie Street
    Edsel
    South Carolina
    Just looked that up. Looks interesting. Do you have a lift on your truck? Or any suspension work done?
  19. Apr 28, 2021 at 10:42 AM
    msmmce1
    msmmce1 New Member
    No lift, stock tires but. Works fine for me, Google says it has a max height of 17" but the adapter should add an inch or two. I'll measure it when I get a minute.
  20. Apr 28, 2021 at 11:27 AM
    Damie Street
    Edsel
    South Carolina
    Awesome thank you. Looks like it my be another good option. I don't really want to get a Hi Lift jack. I have heard horror stories plus they are pretty big and bulky, I'm trying to by as minimal and compact as possible.
    So far Safe Jack with a 4x4 or 4x6 is my first option.
  21. Apr 28, 2021 at 5:29 PM
    Zero One Actual
    Yes I did. It works well. I’m on 37’s with a 3 inch lift. I also have weld on sliders I can put it under as well.
  22. Apr 28, 2021 at 5:36 PM
    Damie Street
    Edsel
    South Carolina
    Thanks for the info. Do you have an adapter for the sliders?
  23. Apr 29, 2021 at 6:34 AM
    Zero One Actual
    No. I do not. It comes with two adapters that you can swap out depending on the situation. One is flat. One is a collar. See attached photo.
  24. Apr 29, 2021 at 2:05 PM
    Damie Street
    Edsel
    South Carolina
    :spending:
  25. Apr 29, 2021 at 2:31 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Just curious, what kit did you end up with?
    I’m on a similar suspension set up, just with 35’s. TIA!
  26. Apr 29, 2021 at 4:51 PM
    Zero One Actual
    GAknight[QUOTED] likes this.
  27. Apr 29, 2021 at 6:02 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
  28. Apr 30, 2021 at 5:29 AM
    Zero One Actual
    Gee Dub and GAknight[QUOTED] like this.
