Hi Guys! Just turned 100K miles...
Discussion in 'New Member Introductions' started by Photogirl, Jun 21, 2016.
  1. Jun 21, 2016 at 5:13 PM
    Photogirl
    Photogirl [OP] New Member
    Brit
    2007 Tundra Black/Black
    Just turned 100K miles on my 2007 Black beauty. I'm a 2nd owner and haven't had any issues with the truck at all.. I don't think the original owner followed the maintenance schedules (I know the timing belt has been changed and oil changes have been very regular.) What should I do now? help! Thanks
    Yotalover88 and mdavis like this.
  2. Jun 21, 2016 at 5:18 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Welcome to the site! Glad your Tundra is treating you well.
    By the way, Toyota changed their timing belts to timing chains in 2007. Never needs replacing. :cool:
  3. Jun 21, 2016 at 5:20 PM
    Photogirl
    Brit
    I meant serpentine belt, sorry
  4. Jun 21, 2016 at 5:24 PM
    Photogirl
    Brit
    Can someone list (in order) what they would do if their Tundra had 100K miles and hadn't had any scheduled maintenance performed. Maybe I can do a little at a time ;)
  5. Jun 21, 2016 at 5:24 PM
    Mike Tread lightly.
    south carolina
    Does the belt look cracked, change in color, or ripped, tears or squeak when starting(getting loose) if so change it.. if not it's generally ok..
  6. Jun 21, 2016 at 5:25 PM
    Photogirl
    Brit
    Umm, belt has already been changed. That's the one thing I know has been changed. Thanks ;)
  7. Jun 21, 2016 at 5:26 PM
    Photogirl
    Brit
  8. Jun 21, 2016 at 5:32 PM
    Mike Tread lightly.
    south carolina
    Ok
    Any records of when the transmission was serviced or water pump changed transfer case and diffs oils where changed last?
  9. Jun 21, 2016 at 5:35 PM
    Photogirl
    Brit
    No, when are those recommended?
  10. Jun 21, 2016 at 5:40 PM
  11. Jun 21, 2016 at 5:42 PM
    Mike Tread lightly.
    south carolina
    By the book at changes oil changes transfer transmission and diffs are 128k for your truck. .. that's assuming the previous owner did it by the book.
    Water pump you just keep a eye on it for leaks.. there is no set change out on it.. when it leaks replace.
  12. Jun 21, 2016 at 5:44 PM
    Photogirl
    Brit
    Awesome! Thank you! I'm new to all this
    Yotalover88 likes this.
  13. Jun 21, 2016 at 5:50 PM
    Mike Tread lightly.
    south carolina
    Glad you joined.. welcome to the site.. check out some of the build pages if you want to go broke... lol
    Yotalover88 and T-Rex266 like this.
  14. Jun 21, 2016 at 5:52 PM
    Photogirl
    Brit
    lol, i better stay away from those... I have expensive taste :)~
    Yotalover88 and Law323 like this.
  15. Jun 21, 2016 at 6:02 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Congrats on the buy and welcome to Tundras. That Tundra is probably just getting broken in, haha. That maintenance guide is a great resource, and it's definitely a great idea to learn the info here before going to the garage for service.
    Post up some pics of the new ride when you can!
  16. Jun 21, 2016 at 6:06 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Eh, start small (easier said than done) build slow, and do as much of it yourself as you can. You'll have a buck or two left over! LOL for me, had to start out with a lift and tires, interior LEDs, window tint, and MPG mod. Getting wheels in a few months I still have enough to buy a stick of gum or two! Hahahaha
    NewImprovedRon likes this.
  17. Jun 21, 2016 at 6:10 PM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    Welcome from TX. Go to a local lube shop and they'll be happy to pull a sample of your fluids and they'll tell you which ones might need replacing. Go to one you trust though.
    NewImprovedRon and Law323 like this.
  18. Jun 21, 2016 at 6:14 PM
    Nor7
    Look at this guy, married to a doctor and complaining about buying chewing gum.
  19. Jun 21, 2016 at 6:20 PM
    Welcome from CO, Brit. I just finally turned over 67K today. If you were lucky enough to have the original users manual for your 07, it will show all the recommended preventive maintenance intervals and what should have been done. I got lucky. I have full maintenance records from day 1. First thing you need to do is log on to Toyota Owners.com. Register, enter required info, including the VIN#. Any history of your Tundra, by the dealer or previous owner, if ever recorded will show up. If there is nothing, then start a new record. I'd forget "local" lube shop at first. Go to your local dealer for the first look around/background check. "Local" lube shop won't know crap about your Tundra.
  20. Jun 21, 2016 at 6:29 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Hahahahahahaha!! Hey, she just graduated five days ago and all the mods I've done so far were pre graduation! Give it a couple years, after student loans are done, I'll be complaining about which tundra to drive to work, would that make you feel better? :quickdraw:
    TruckyTruck and Yotalover88 like this.
  21. Jun 21, 2016 at 6:30 PM
    For what's it worth, I feel better.
    Law323 likes this.
  22. Jun 21, 2016 at 6:33 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Go ahead....make my day
  23. Jun 21, 2016 at 7:59 PM
    She could have a 4.7L motor in an 07, and they need TB change outs.
    T-Rex266 likes this.
  24. Jun 22, 2016 at 5:05 AM
    mdavis
    Michael
    Rock Hill, SC
    True, I assumed she had either the 4.6 or 5.7.
  25. Jun 22, 2016 at 5:26 AM
    I would assume the same.
    Maybe she can clarify for us what motor is installed in the truck.
  26. Jun 30, 2016 at 8:15 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Welcome!
  27. Jul 2, 2016 at 10:34 AM
    15whtrd
    15whtrd Mr. Blonde
    Im a firm believer in fluid changes front to back for piece of mind. Don't forget the brake fluid.
  28. Jul 2, 2016 at 10:59 AM
    owslystnly
    owslystnly New Member
    White 2016 SR5 Crewmax w/ SR5 upgrade+TRD Offroad
    Nothing yet
    I'm going to turn 1K miles today! :thumbsup:
  29. Jul 2, 2016 at 11:01 AM
    Yotalover88
    Yotalover88 "If it ain't broke don't fix it"
    James
    2013 white tundra
    Rhino liner, bed mounted tool box "no stripper pole" paracord wrapped oh shit handles, Lowes stair tread door seal protectors, handgun holder for my dedicated truck gun. My list of wants is much longer!
    Hey I feel you trust me my wife is chief resident this is her last year of residency what a long road! Some day maybe she will let me put on a bull bar and winch! Congrats on your wife graduating!
    Law323[QUOTED] likes this.
  30. Jul 2, 2016 at 11:30 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Thanks bud! Congrats on your wife almost finishing up residency! Yep, long road that's for sure! She's starting her residency in a month up in Memphis. At least she's getting paid huh?? No more loans!
    Yep, I'm working on a suspension kit in place of my spacers and some wheels. Better start brown nosing now!! :crapstorm:
    Yotalover88[QUOTED] likes this.
