Hi folks, brand new to this forum! Every so often I can't figure out problems with my T
Discussion in 'New Member Introductions' started by Crabster, Apr 20, 2022.
  1. Apr 20, 2022 at 8:27 AM
    Crabster
    Crabster [OP] New Member
    Craig
    05 Gray Tundra 4X4, 4.7, Limited Access Cab
    5" Lift, Wheel wells trimmed
    Need help on this one! My "05" Tundra, 4X4, 4.7 I injured something in my front left suspension, foolishly making a strong U-turn on pavement! I've changed my steering rack and lower control arms (they needed it anyway)but the problem still exists! Symptom is when turning wheel left for a 45 degree turn or more and light to strong acceleration, my steering grabs (almost locks) and I have to pull it out of turning left! Not a good thing! Has anyone had this same problem and know the answer to fixing it? Graciously looking for the fix, thanks kindly folks!
    YardBird likes this.
  2. Apr 20, 2022 at 4:57 PM
    RoadtripJim
    RoadtripJim New Member
    Cedar, MN
    2021 Silver SR5 - TRD Double Cab
    Welcome and greetings from Minnesota. You might want to check out the “ask a Toyota mechanic” thread for your answer.
  3. Apr 20, 2022 at 5:10 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  4. Apr 20, 2022 at 5:54 PM
    Mr Badwrench
    Mr Badwrench New Member
    Check your lower ball joints.
  5. Apr 20, 2022 at 5:57 PM
    Welcome from NY.
  6. Apr 20, 2022 at 6:12 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Also, maybe make sure that you aren’t locked in 4wheel drive. You should be able to manually turn the front drive shaft if you crawled under and try.
  7. Apr 20, 2022 at 7:06 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  8. Apr 21, 2022 at 3:08 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
