HHO Hydrogen Generator
Discussion in '2.5 Gen Tundras (2014-2021)' started by xj2202009, Apr 23, 2018.
  1. Apr 23, 2018 at 7:11 PM
    xj2202009
    xj2202009 [OP] New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
  2. Apr 23, 2018 at 8:35 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Never heard of it but sounds like they may have left this out of the kit...
  3. Apr 24, 2018 at 6:47 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
  4. Apr 24, 2018 at 6:54 AM
    Trooper2
    JR
    I am sure if something like this were worthwhile or we would be seeing more of it, at least some (or one). Noticing the 1yr warranty, probably not working much longer, guessing not long enough for the investment / payback.
  5. Apr 24, 2018 at 12:33 PM
    LlamaResistance
    LlamaResistance Member
    Concord, CA
    2017 White Crewmax SR5 TRD Offroad
    MLED Retrofitted Platinum Headlights, Ranch Hand bumper, Firestone airsprings, Leer 100XR Shell, Amp Research Steps
    :poking:
    Doesn't do shit. Makes steam at best, not Hydrogen. There is a reason our hydrogen gas is sourced from Natural Gas not water. Even if it did make hydrogen, you first had to burn fuel to spin the engine, to turn the alternator to make electricity, to separate hydrogen from oxygen (f'n hard to do without a catalyst) and then burn the hydrogen. Power losses in the engine (chemical to mechanical energy), drive belts (slippage), generator (electrical to heat energy), and then back to the engine make it less than worthless. The people that peddle this crap have no shame and know jack shite about chemistry and engineering.
    Black Wolf, 15whtrd and Pudge like this.
  6. Apr 24, 2018 at 12:43 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I'm no expert, but i had a "du fuk?" moment when reading this
    you usually use a catalyst, and you could separate the anode and cathode (still in the same system) if you wanted just hydrogen
    Black Wolf and Pudge like this.
  7. Apr 24, 2018 at 1:21 PM
    LlamaResistance
    Concord, CA
    Electrolysis works but for very high energy cost. No catalyst required but very inefficient.
    Catalyst based conversion is being worked on at the moment.
    https://www.technologyreview.com/s/428260/a-better-way-to-get-hydrogen-from-water/
  8. Apr 24, 2018 at 3:36 PM
    xj2202009
    x
    Lutz, Fl
    Thank you.. I have read about these in the passing but have never looked into it. Thank you gentlemen.
  9. Apr 24, 2018 at 4:01 PM
    A helium generator would be a lot more fun..and you would be rich too!
