Hey everyone, is anyone riding with stock wheels but aftermarket tires?
Discussion in 'Wheels & Tires' started by Tundra.v2, Dec 9, 2016.
  1. Dec 9, 2016 at 1:42 PM
    Tundra.v2
    Tundra.v2 [OP] New Member
    07&15 Tundras
    I would want to keep the stock wheels and add a leveling kit on my truck and upgrade to some toyo tires. Is it possible? Would love to go with 35s by the way
  2. Dec 9, 2016 at 1:48 PM
    14tundra
    14tundra On Wisconsin!
    WI
    2014 Platinum Crewmax 4x4 5.7L 1G3
    What wheels do you have now? SR5? Limited? Platinum? 1794? PRO?
  3. Dec 9, 2016 at 1:50 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Yes possible but width of the tire will be the factor. May need to add 1.25" wheel spacers like I did.
    I have the RW wheels with 1.25" Spidertrax wheel spacers for a end offset of 18.24mm. Wheel offset was +50. Yours will be +60. The width of tire that I have is about 11.5".
  4. Dec 9, 2016 at 1:50 PM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    I had SR5 wheels and upgraded to my Discover STT Pro tires
  5. Dec 9, 2016 at 1:50 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Can be done but you're definitely going to need some wheel spacers
  6. Dec 9, 2016 at 2:03 PM
    Tundra.v2
    07&15 Tundras
    18" Stock TRD wheels
    What's the biggest I can go with not adding any type of lift or spacers?
    What would be the biggest I could go with only adding 2.5" spacers? Thanks for the help guys
  7. Dec 9, 2016 at 3:01 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    With 2.5" spacer lift and maybe some wheel spacers you can probably get 285/70/18 in there without any major cutting.
  8. Dec 9, 2016 at 4:39 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    I fit LT285/70R18 Nitto Exo Grapplers on my Tundra with Fox 2.0 coilovers (~2.5" of lift), SPC Light Racing upper control arms (slightly larger than stock), with stock rear leaf springs, and have experienced no rubbing issues off-road. If you go with 12.5" wide tires you will need spacers but if you got a tire like mine or a LT285/75R18 (35") you'll probably be OK. Depends on the tire too. The lugs on something like the Toyo M/T stick out pretty far and would probably not clear.
    Y0TA PR0 likes this.
  9. Dec 9, 2016 at 5:04 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I'm running 295 75 18 STT pros on stock TRD wheels with 1.25" spacers. I have something like 3.5" of lift in the front and 1" rear.
  10. Dec 9, 2016 at 6:55 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Check my build thread. I am running a 35" tall tire, just little narrower than a 35x12.50-18. I run a 285/75R-18 nitto G2 on oem wheels, no spacer, no body mount chop and plenty of UCA clearance. Good luck with everything. And yes I articulate the heck out of the suspension off-road.
  11. Dec 9, 2016 at 7:54 PM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    I"m running the BFG KO2's on my stock TRD Wheels. Size in signature if needed.
    blizz86 and Y0TA PR0 like this.
  12. Dec 9, 2016 at 7:56 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    That's a sweet blue truck! Should be in the blue thread too lol :thumbsup:
  13. Dec 9, 2016 at 7:57 PM
    Krezz
    Kevin
    Thanks man! I've been lazy but I plan on doing a build thread, just so I can have a spot when I"m bored to constantly look back over my truck as she's grown over the past months hahaha.
  14. Dec 10, 2016 at 3:30 PM
    hokieskins
    hokieskins New Member
    Hokie
    2015 Tundra 1794
    Running the new Ridge Grapplers 295/60R20 with 3" ToyTec lift, Spidertrax 1.25 Spacers, Removed front flaps, push the liner forward and heatgun the rear liners.
    Was contemplating the 35x11.5, they could fit without the mud flaps.
    Love the ride and tires are really quite.
    Tundra.v2[OP] likes this.
