Here’s why you cut your exhaust tips when adding longer shackles
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by gosolo, Mar 4, 2018.
  1. Mar 4, 2018 at 4:30 PM
    gosolo
    gosolo [OP] You Don’t Know Who I Am But I Know Where You Live
    Ray (or maybe Dale)
    NW Oregon
    This is only a problem if you get full droop, but as you can see, with a wheel off the ground the exhaust would be getting torn right off the truck..
    4AF84842-3DF7-4BEA-82E0-8FED3B3F94EB.jpg 4430FED9-D66C-449A-8967-0F4DE939FA6E.jpg
  2. Mar 4, 2018 at 6:25 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    +2”
    If you don’t have place you can check it when out wheeling, jack up one side of your truck by the frame, allowing the wheel and axle to drop. This way you will know for sure
    NewImprovedRon and 831Tun like this.
  3. Mar 4, 2018 at 6:30 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I had this crazy idea that I'd sell the pipes so I bought dumped tails from Keith.
    joonbug likes this.
  4. Mar 4, 2018 at 7:23 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I doubt that the stock springs will hit the regular pro exhaust but i don’t know. I didn’t check beforehand.
    Watt maker likes this.
  5. Nov 20, 2018 at 6:22 AM
    matt kruckenberg
    matt kruckenberg New Member
    slc ut
    2015 Trd Pro Inferno
    I had +3 shackles from coachbuilder did not interfere with exhaust
    After installing icon spring pack option 3 I cut them off
    Rica25 likes this.
  6. Nov 20, 2018 at 6:26 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    How do you like your icon springs? I’m thinking of going with modified Deavers. I’m curious to know the specifications on the springs you have. Thanks
  7. Nov 20, 2018 at 6:30 AM
    matt kruckenberg
    slc ut
    Could not he happier
    I have a decked system with 5 to 600 lbs all the time and also load a lot
    I find myself aiming at rough spots all the time
    Just need to get shocks and bump stop and switch out shackles for the ÷1
    gosolo[OP] likes this.
  8. Nov 20, 2018 at 6:33 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I’ve also got the Decked Drawers. Plus a cap and 46g fuel tank. The constant static load definitely requires the upgrade!
    matt kruckenberg and 15whtrd like this.
  9. Nov 20, 2018 at 7:19 AM
    matt kruckenberg
    slc ut
    I have the option 3 rxt spring pack
  10. Nov 20, 2018 at 8:10 AM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    Probably don't want the exhaust aiming at your leaf springs. The heat will melt your leaf spacers, looks like they're already starting to melt.
  11. Nov 20, 2018 at 8:12 AM
    15whtrd
    15whtrd Mr. Blonde
    I’m sure it’s only aiming at it when he is in full articulation. Otherwise it’s directed below it at normal ride height. It might just look melted from the moisture out of his exhaust.
