Help won’t start
Discussion in '1st Gen Tundras (2000-2006)' started by Knowsenoughtogetintrouble, Jan 23, 2020.
  1. Jan 23, 2020 at 9:53 PM
    Knowsenoughtogetintrouble [OP] New Member
    Marcus
    2000 tundra v8
    Hey guys
    My 2000 V8 won’t start I’ve replaced starter, starter relay, and battery
    I’ve bypassed the ignition and still no start just relay click
    Any help would be greatly appreciated for I’m all out of ideas here
  2. Jan 23, 2020 at 10:05 PM
    Aerindel
    Aerindel New Member
    Montana
    What clicks? The starter?
    Can you turn the engine over by hand?
  3. Jan 23, 2020 at 10:16 PM
    Marcus
    2000 tundra v8
    The relay clicks and yes I can turn the engine by hand
  4. Jan 23, 2020 at 10:23 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Gas..fuel pump..?:notsure:
  5. Jan 23, 2020 at 10:25 PM
    Aerindel
    Aerindel New Member
    Montana
    Well, if the starter is new and its clicking but not turning over that usually means bad terminal clamps or wires. Enough voltage to run the relay, not enough to turn the engine.
    Try jump starting it with another vehicle as a running vehicle runs a couple volts higher than even a freshly charged battery and may have enough juice to turn it over. Which if nothing else will show that the starter works.
    speedtre likes this.
  6. Jan 23, 2020 at 10:25 PM
    Aerindel
    Aerindel New Member
    Montana
    Would not have anything to do with it not turning over.
  7. Jan 23, 2020 at 11:28 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    There’s a good chance you bought a Chinese reman starter and that the solenoid on said “new” starter is bad.
    Jump the starter.
    Check voltage at the starter while you are at it.
  8. Jan 24, 2020 at 3:32 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    I know the starter is buried, but if you can find the signal wire in the harness that goes to the starter, that is the small wire on the back of the starter. When the key goes to start position, with a test light this should light up. If it lights up, it's a starter issue. If it does not light up, you have a problem in the starter circuit. You should ALWAYS do this test before replacing a starter.......especially when it's buried under the manifold. Starters that are exposed are easier to test of course. Of course #1, better make sure battery is ok, and all those connection on the positive side are ok. It's amazing what corrosion can do. Think simple. A battery can have 12 volts, but lost it's cranking power, so keep that in mind. So also, with the thought of you can't go any where without a battery, because you know it's like very important to vehicle function.................go buy an Interstate battery, and stay away from cheap crap, and keep your terminals clean........shit....keep the whole battery clean. A dirty battery can cause drain. Note: Interstate has facilities where you can buy batteries not fit for the shelf, because of a scratch or a ding, and discounted.
    Whothefat and speedtre like this.
