Help with wiring lights
Discussion in '3rd Gen Tundras (2022+)' started by Fly Fisherman, Oct 7, 2023.
  1. Oct 7, 2023 at 8:00 PM
    Fly Fisherman
    Fly Fisherman [OP] New Member
    Paul
    2023 Tundra Limited TRD Off Road
    TRD Pro Heritage Grill TRD OEM grill marker lighte
    I just bought by 2023 Tundra Limited. I upgraded the grill to the Pro Heritage style and I installed the TRD Pro grill marker lights, as well as the TRD Pro front light bar. All OEM, nothing aftermarket. While it’s pretty simple to buy OEM parts, thanks to everyone’s directions on the forum, how to wire these light correctly? Can you purchase the OEM wiring harness for what I just described above? Local dealerships (x2) are a bit baffled. Any advice would be greatly appreciated. Thank y’all.
  2. Oct 8, 2023 at 2:53 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Welcome aboard!
    I did the swap but used a Rave set of lights with a fuse tap. Was super easy but the lights aren't the same as the Pro lights. I may just switch them to the Pro lights to get the little "TRD" in each light.
    I have the Pro fender flares and will wire those lights into the same fuse tap for simplicity. I think the light bar will be tough as it ties into the other lighting on the truck and has some conditions where the light bar will not come on. I am looking at the aftermarket light bars which will be more typical to wire with a switch and relay.
    Have a look at the various threads that go into detail on the wiring.
    https://www.tundras.com/threads/grille-interchangeable.100356/page-2
  3. Oct 8, 2023 at 2:58 PM
    Fly Fisherman
    Paul
    Thank you! Glad to be able to hear great ideas and advice. I’ll take a look at the thread you shared. I guess I just like OEM stuff and didn’t think it through. I think the proprietary PRO line stuff may come out in later years but after talking to a body shop friend of mine, they have to provide the VIN number to even get correct parts for repairs??
