Help with tire/wheel combo
Discussion in 'Wheels & Tires' started by Tundrarunner4s, Feb 23, 2020.
Tire/wheel combo
  1. 275/70/18 LT
    14 vote(s)
    100.0%
  2. 275/60/20 SL
    0 vote(s)
    0.0%
  1. Feb 23, 2020 at 6:44 PM
    Tundrarunner4s
    Tundrarunner4s [OP] New Member
    2023 MGM Tundra Platinum
    Cooper discover RT
    Hey guys, first time posting but have been a frequent reader. So much helpful information on here. Wondering if I could get some input on my setup.
    Looking to go to 33’s from stock but was really wanting to avoid sacrificing ride and what little mileage I get by going 10-20lbs heavier than stock with an lt tire. I have stock 18” trd wheels and am seeing not many choices for 33’s in SL tires. It does look like if I swapped out for some 20’s I could get a 275/60/20 in SL’s and just add approx 10 lbs per corner as opposed to 15-20lbs per corner with 275/70/18’s in LT tires. My question is, since the assumption is with 18’s I’m already getting a softer ride, would the ride compromise with LT’s be negligible? How about MPG’s? I get about 13 normally around town and 17-18 on extended highway trips. I’ve never run an LT tire before so not sure what to expect in compromises to power and mpg and will only tow/haul anything substantial probably <6x per year. Any advice or personal experience is appreciated.
  2. Feb 23, 2020 at 7:59 PM
  3. Feb 24, 2020 at 9:11 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    Going to a 275/70/18, you likely won't see a noticeable difference in power. For the MPG, I would say bank on a 1 mpg loss. I personally wouldn't swap out the 18's for 20's, just to get a tire that is not an LT. I doubt you would even see much of a difference in mpg honestly between the 275/70/18 in an LT and the 275/60/20 SL's.
    What type of tires are you looking to run? Wanting still a hwy tire, AT's, etc?
  4. Feb 24, 2020 at 9:28 AM
    Tundrarunner4s
    Cooper discover RT
    Thinking if I went LT probably the cooper discoverer at3 xlt...it’s about 13lbs heavier per tire than stock I believe.
  5. Feb 24, 2020 at 2:26 PM
    Going to the 275/70/18 you are only going about an inch bigger. The stock tire is around a 32.1. I definitely wouldn't go to a 20. Going from an 18 to a 20 will kill your mpg.
  6. Feb 24, 2020 at 3:07 PM
    Tundra_power
    Tundra_power New Member
    Nick
    Unsprung weight is huge for mpg and performance. 10lb per corner is 40lb all together. rule of thumb 1lb of unsprung weight is about 10lb dry weight in the bed but it could vary. So typically you will be gaining 300-400 more pounds in the truck just switching tires. Now remember its where the weight is on the hub. If its closer to the hub its not that drastic. Tires will play a bigger role than wheels do as for unsprung weight because most of the weight is away from the hub as oppose to wheels. Now im not saying go with 20s it all depends what you do. If go offroad alot or crawling thats needed for the extra sidewall. 18" will be lighter than 20" which does matter and they will ride nicer because of the extra rubber and typically same size tires for 20" or 18" will weight the same. You could do 275/65 r18 nitto terra g2 on some 18x10 -18 ish. It will stick out but it will give the wide stance for aggressive look at the same time you will not gain any weight. G2 are 44 pounds and 18" can get down to the 28. I think moto metal 18x10 are 28 pounds.
  7. Feb 24, 2020 at 3:38 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    I put 33x12.50x18 on +12mm offset, no lift, no rubbing
    jewsNbrews likes this.
  8. Feb 24, 2020 at 3:47 PM
    bobwalk2002
    bobwalk2002 New Member
    Bobby
    Prescott, AZ
    2010 Tundra SR5 Double Cab TRD Off Road 4x4
    None yet.
    I am running Falken Wildpeak A/T LT295/70 R18 (Load Rating E) on stock 18" TRD rims. Could not be happier with the tires, very quiet and smooth on pavement and highly capable in snow and dirt. Have a 3 1/2" Rough Country lift and had to remove front mud flaps and trim skid plate 2" on each side (didn't want to use spacers). Averaging about 16MPG driving mostly around town (we have no freeways where I live).
  9. Feb 26, 2020 at 7:07 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    275/70/18 on stock suspension works and looks great. LT tires will reduce MPG a little and the ride is going to be a little stiffer....but you can chalk test the tires and experiment with air pressure to get the best ride with a good contact patch.
    Ill be installing that size on my stock Crewmax when it is time to replace tires....for sure!
  10. Feb 26, 2020 at 7:09 AM
    frichco228
  11. Feb 26, 2020 at 4:44 PM
    18sport
    18sport New Member
    Russell
    18 sport cm
    Just went to 275-65-20 cooper discovery at3 on 20x9 Greg weld and I love the look
  12. Feb 26, 2020 at 4:51 PM
    Tundrarunner4s
    Cooper discover RT
    Any pics of the setup? Did you go LT? If so how does it ride vs stock?
  13. Feb 26, 2020 at 4:53 PM
    18sport
    18sport New Member
    Russell
    18 sport cm
    Just put them on tonight I have had the wheels for 9 yrs and added the at3 earlier today so far ride the same
  14. Feb 26, 2020 at 4:55 PM
    Tundrarunner4s
    Cooper discover RT
    Looks great! Interested to hear how they ride as you get more miles on them.
    18sport[QUOTED] likes this.
  15. Feb 26, 2020 at 4:57 PM
    18sport
    18sport New Member
    Russell
    18 sport cm
    I will let you know for sure there quiet the way I wanted and got the stance I was looking for
