Help with tire size decision
Discussion in 'Wheels & Tires' started by oj913, Dec 30, 2019.
  1. Dec 30, 2019 at 12:39 PM
    oj913
    oj913 [OP] New Member
    OJ
    2016 Tundra SR5 Crew Max
    Hi all,
    I recently bought a tundra earlier this year so I am new to this forum. I love all the useful information, thank you all.
    I purchased a set of bronze Fuel Shok D666 18x9 +20mm offset. I have been going back and forth on deciding a tire size. I have narrowed my tire brand/model decision between the Toyo Open Country R/T and the Nitto Ridge Grappler. I have a 2" front level kit on the truck right now (stock rear), but I plan on doing the 6112/5160 kit later this year.
    By biggest confusion right now is deciding on what size to go with I am between:
    33x12.5r18
    285/70r18
    285/65r18
    I love the look of the 12.5 width tire but i wanted to make sure this fitment would be do-able with my offset with slight modifications. I dont mind losing the mud flaps but I would like to avoid a BMC. Any inputs? I hate to make another "will this fit" thread but I cant seem to find a solid answer by searching :)
    O
  2. Dec 30, 2019 at 12:58 PM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    I would probably run the 285/70/18 on that setup. It's about an inch taller than those other two, and will still give you decent width on the rims and truck.
  3. Dec 30, 2019 at 4:40 PM
    NJUplandTundra
    NJUplandTundra Toyota Fanatic
    Michael
    2015 Limited CrewMax
    6112-5100, SCS Ray10, 275/70/18 AT3 XLT, SPC UCAs, TRD CAI, TRD Pro Grill
    Another vote for 285/70/18. You shouldn't have many rubbing issues, only slight trimming of fender liners usually
  4. Dec 31, 2019 at 12:34 PM
    oj913
    OJ
    Awesome, thanks guys. I see you both are running the 275/70/18's. Does it seem like there is a lot of clearance left for 285/70's? I've read that numerous people run the 285/70 set up no problem on stock wheels. I'm hoping my offset wont be an issue.
  5. Jan 1, 2020 at 10:43 AM
    parker44
    parker44 New Member
    I could likely clear them on my 08 with my 2” spacer, possibly minor rubbing on the fender but not sure. For what I’m running, the 275/70/18 is the best bang for my buck in terms of size and price.
