Help with timing chain on 2008 Tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by kalanz, Feb 16, 2020.
  1. Feb 16, 2020 at 3:44 PM
    kalanz
    kalanz [OP] New Member
    08 toyota tundra vvti v6 4.0
    none
    can anyone help me with the timing chain on a 08 tundra vvti v6 motor
  2. Feb 16, 2020 at 3:45 PM
    Mr Badwrench
    Mr Badwrench New Member
    What do you need help with specifically? Also, which v6?
    Bob likes this.
  3. Feb 16, 2020 at 3:48 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    I think he has a 1GR-FE.
  4. Feb 16, 2020 at 8:40 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    I'll guess that someone has told @kalanz that your Tundra has a code P0016 indicating a stretched timing chain. Linked below is an excellent video (1:30:44) replacing the timing chain on a Toyota 4.0L V6. This is a huge job. Episode 5 shows the actual timing chain replacement. If you want to see how the diagnosis was made, start at Episode 1.
    Edit @kalanz: Starting at Episode 1 will be time consuming, but could actually be beneficial. There are other possible causes of code P0016 that have to be eliminated.
    https://www.youtube.com/watch?v=UR50da0sDOc
    Failure2comply, Bob and bleach like this.
  5. Feb 16, 2020 at 9:11 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    Most timing chain jobs are far bigger jobs than belts. Looks like we have some good sleuths here on this forum.
    Bob likes this.
