Help with sag when pulling trailer. Thanks
Discussion in '2.5 Gen Tundras (2014-2021)' started by snappy924, May 9, 2021.
  1. May 9, 2021 at 9:34 PM
    snappy924
    snappy924 [OP] New Member
    Garrett
    Pasadena, California
    2017 Tundra Crewmax 4x2
    Bilstein shocks, Tembren bump stops,
    Pulling my trailer with 4 bikes hanging over the tailgate. Running Bilsteins 5100 with the front leveled. Installed the Timbrens bump stops, but I wanted to see what other options I have instead of getting airbags? Thanks.
  2. May 9, 2021 at 11:53 PM
    Doug2000
    Doug2000 New Member
    London, Ontario, Canada
    2017 Tundra SR5 5.7L DC 4X4
    Post a picture of your setup loaded. Do you have the ability to add a Weight Distribution Hitch. I have WDH to pull my travel trailer. The WDH redistributes weight from your back axle to the front axle and trailer axle. You load up the torsion bars so you sit at a stock height. Check Craigslist, you could probably find one for $100.
    Random video here. One thing he doesn't show, measure your 4 fenders before you start. set the preload so your truck sits at factory height with the bars engaged. Airbags are the last thing I would consider. They tend to burst at the most inconvenient times according to towing forums,
    WDH also make your ride a lot more enjoyable and smooth.
    Weight Distribution Hitch Explained - YouTube
  3. May 10, 2021 at 12:36 AM
    18" TRD Off Road Wheels
    Purely cracking a joke here, but the dude's trashcan size exhaust tip has me questioning everything he says....
  4. May 10, 2021 at 1:27 AM
    Doug2000
    Doug2000 New Member
    trucknut and GODZILLA like this.
  5. May 10, 2021 at 6:13 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    You can check into roadmaster active suspension. It will help with sag and towing and is an option other than air bags. Other than that, you could look into replacing the leaf springs or do an add a leaf if you are towing a lot.
    FlightMedicRN likes this.
  6. May 10, 2021 at 6:49 AM
    FlightMedicRN
    FlightMedicRN New Member
    2020 Super White Crew Max- TSS SR5
    Interior chrome delete- AJT Designs, S&B Cold air intake, 10" BAMuffler exhaust system, color-keyed bumper covers, LED fog lights, TuffSkins interior inserts, black exhaust tail pipe and tip, Peragon tonneau cover.
    What he said....I have the Roadmaster Active Suspension installed on my 2020 Crewmax but haven't had the opportunity tow our 27ft TT since I installed. I already have a Husky Centerline TS weight distribution hitch and besides distributing the weight to the front of your truck and back to some of the TT, the hitch definitely eliminated trailer sway for me and improved handling while towing.
  7. May 12, 2021 at 6:51 AM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    Black SumoSprings on my truck. Maintenance free and work great, wouldn't go any other way.
    Avi8or likes this.
  8. May 12, 2021 at 8:04 AM
    Fastestcolor
    Fastestcolor New Member
    Blue Ribbon Limited CM
    I tow a 7500lb boat with a tongue weight about 700lbs. I have a little squat on the truck but only enough that the truck has a leveled look and not tail low. My truck is not leveled. If you’re towing regularly I’d recommend losing the level and the truck most likely won’t sit tail low with that little trailer. When we start adding a bunch of suspension add ons it’s usually not as good as staying stock if you’re towing. You leveled and now you’re trying to counter the level with more suspension goodies. Toyota put a rake on the truck because they made it to tow. The pro is made to be off-road which is why it’s lifted.
  9. May 12, 2021 at 8:07 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    I agree that a properly set-up WDH is your first priority.
    You could also consider mounting your bike rack on the trailer bumper, but you will have to forward bias any gear loaded into the trailer to off-set the bike load. This is not something you should do blindly. Once you've loaded the bikes and all the typical gear into the trailer, probably a good idea to weigh the trailer and it's tongue weight to insure tongue weight is still about 10% of trailer weight.
    Loading the bikes on the trailer axle(s) would reduce the Tundra's payload directly by the weight of bikes and rack. But, don't get too excited...the weight of the WDH has to be counted directly against your payload.
  10. May 13, 2021 at 9:19 PM
    snappy924
    Garrett
    Thanks for the heads up on possible mounting bikes on trailer hitch.
  11. May 13, 2021 at 9:22 PM
    snappy924
    Garrett
    I went with the Timbrens, but maybe I need a heavier duty set?
  12. May 14, 2021 at 8:19 AM
    clarkritchie
    clarkritchie New Member
    To each his own, but when I used a 4-bike rack on the rear of a single axle travel trailer, I found that even nominally sized bumps caused the rack to bounce pretty bad due to the lever effect, even with a WDH and airbags on my F150. That is just my own experience. If you have a two-axle trailer, perhaps this is a non-issue.
  13. May 16, 2021 at 5:41 AM
    2mchfun
    I have a heavy trailer, so to be comfortable I have a good weight distribution hitch, Dobinson's HD springs, Roadmaster HD active suspension, and yellow HD Sumo spring bump stops. I loaded over 2200# in the bed yesterday and was still a solid 1" from making contact with the Sumo springs. I guess you could say it dropped 1.25" with over one ton in the bed and 1200# of that was at the rear with the tailgate down, probably about 600# actually on the tailgate itself. If you want to haul a load squat free I highly recommend this setup, also rides like a Cadillac full or empty. Thanks, Bilstein 5160's!IMG_20210515_201814_2.jpg IMG_20210515_201819_2.jpg
    MrJonnb likes this.
