Help with pro skid plate oil filter access panel hardware
Discussion in '2.5 Gen Tundras (2014-2021)' started by Brimaster, Jun 22, 2020.
  1. Jun 22, 2020 at 6:01 PM
    Brimaster
    Brimaster [OP] New Member
    2017 Magnetic Gray Metallic DC TRD
    Was cleaning the truck over the weekend and went under to clean the skid plate from the oil residue and noticed one of the bolts from the access panel is missing. Not sure if the dealer never put them all back on at the last oil change or it worked lose and fell out.
    Did some searches and can't seem to find any information.
    Anyone know of the part number for them so i can order up some replacements or any other bolt options that would work?
    Thanks in advance.
  2. Jun 22, 2020 at 6:30 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    What I would do is remove the remaining bolt and take it to a hardware store that has all those trays and drawers of nuts and bolts and find one that matches. Personally, I'd select stainless.
  3. Jun 23, 2020 at 12:39 PM
    Brimaster
    Thanks looking like I'll have to give that a shot.
  4. Aug 16, 2020 at 4:15 PM
    Brimaster
    well, finally was going to address this and come to find out the bolt was not missing the dealer busted off one of the bolts and striped out the head on another so it will turn into one PITA. Will have to pull the plate to address this now...
    Another reason to do your own oil changes and stay the hell away from the dealer.
