Help with Power port to USB swap
Discussion in '2.5 Gen Tundras (2014-2021)' started by tbkane, Jun 18, 2022.
  1. Jun 18, 2022 at 3:27 PM
    tbkane
    tbkane [OP] New Member
    2017 Tundra SR5 Double Cab
    Reverse power aux lights Boost auto fold mirrors Switched reverse lights Trying to switch power port to USB: failing
    Wanted to replace my rear seat power port with a USB, so I bought this one:
    https://www.amazon.com/Cllena-Charger-Socket-Outlet-4-2A-Blue/dp/B01HPSY596?ref_=ast_sto_dp&th=1
    It came, I removed the rear console and took out the power port. Cut off the toyota connectors, swapped on red female connectors, crimped them down and plugged it in. Red to pos and white/black to ground. no joy. reversed them. No joy.
    Disconnected them from the new USB and connected them to the old power port and it lights right up. So it is not the connector or the fuse.
    Could be the USB port is bad? is there a power limit to the port, and would a 2 2.1 port exceed it?
    Thoughts on how to resolve?
  2. Jun 18, 2022 at 3:39 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Fuse? It should be as easy as your process... try a 9v battery to the USB and see if it lights up
  3. Jun 18, 2022 at 3:58 PM
    tbkane
    Not fuse, since the old one still works. Will try the 9v and see what I get.
    HulkSmurf14 likes this.
  4. Jun 18, 2022 at 8:34 PM
    MaxPower
    MaxPower New Member
    18 Tundra TRD Off road
    What did the 9v battery do?
  5. Jun 18, 2022 at 9:09 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    ACC has to be on for it to work.
    Either engine running, or key turned to ACC.
    The 12 volt sockets are not powered when the engine and/or ACC is off.
    You might have got a bad plug.
    I installed something like this in the console.
    I didn't cut the leads off the 12-volt connector, I simply tapped into the wiring with Posi-taps.
    It works fine as long as the ACC is on or the engine is running.
    aawawv8m_zpsridvswcc_a7cfdfef7ea1d2ae7be267335a4ca42b69b70cc5.jpg cq2vfxrw_zpsgkik3zng_7dbea8b63d65ec8c2e2c5b51b914e868781275d4.jpg
