Help with Mesh Network
Discussion in 'Technology' started by TundraDan723, Sep 6, 2023.
  1. Sep 6, 2023 at 6:36 PM
    TundraDan723
    TundraDan723 [OP] Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    I recently replaced an EERO Pro 6 mesh network with a new Netgear Orbi 840.
    I have quite a few IoT devices that I would like to keep separate from my main network.
    My question is can I add the EERO, running in bridge mode, behind my Orbi and have all household devices (smart lights, smart switches, exercise equipment, etc) connected to it? Basically I am trying to run two mesh networks at the same time, with one running behind the other.
    I have a 16 port Netgear managed switch and an 8 port switch, both connected via ethernet to the Orbi satellites, but not sure exactly how to configure the managed switch to potentially isolate the EERO.
    Running in the above configuration, all the IoT devices appear in my Orbi app as connected devices, so somehow, even thought they are all wirelessly connected to the EERO, they still how as connected to the Orbi.
    Does this make any sense?
  2. Sep 6, 2023 at 6:44 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Dumb question: are passwords to both networks identical?
  3. Sep 6, 2023 at 6:51 PM
    TundraDan723
    yes
  4. Sep 6, 2023 at 7:02 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    It's no wonder they're showing up connected to both then. Set a different password to the Orbi then make sure none of your devices that you want connected to the other network are using that password.
  5. Sep 6, 2023 at 7:04 PM
    TundraDan723
    I wondered about that. I just didn't want to have to change 30+ passwords on all my devices...:frusty:
    I wondered if it was because the ORBI sees the EERO as a device that has 30+ items connected to it and just passes all the information through to the ORBI admin page.
  6. Sep 6, 2023 at 7:11 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Your IP modem has both connected to it I presume...that alone makes me think they're connected via that factor alone. If you had two different IP modems with one running each network separately, I'd venture to say your desired differentiation would be achieved.
  7. Sep 6, 2023 at 7:12 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    There are smarter ppl than me when it comes to IT-related things in here so I'm sure they'll confirm or deny what I'm saying.
  8. Sep 6, 2023 at 7:40 PM
    TundraDan723
    Agree, and I asked my ISP about connecting them via a switch, both running as a modem and they said that would cause issues with both trying to pull down an IP address.
  9. Sep 6, 2023 at 9:19 PM
    TFT
    TFT New Member
    Troy
    2017 Tundra Limited
    Most new routers allow you to run a separate guest network from the same device. A protected environment, and an open environment.
  10. Sep 6, 2023 at 9:34 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    This
    Why not join your IOT stuff to the guest network? It is sandboxed from your primary network automatically, but still allows internet connection.
  11. Sep 7, 2023 at 3:30 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I believe he'd still have to change the passwords on all the devices in order to switch them to a guest network
  12. Sep 7, 2023 at 3:48 AM
    bflooks
    bflooks New Member
    Metrowest MA
    I'm rocking the TP Link Deco x90 mesh system and their latest update provided an IoT channel as well as the traditional Guest and Primary. Only runs at 2.4ghz but was a pleasant surprise since I previously had to setup the IoT devices with a parental rule that only gave them 2 services so they could function. Better than nothing, but I'll take the dedicated channel with unique SSID and password.
    Might be worth confirming there isn't an update available for yours that will offer something similar.
    TundraDan723[OP] and texasrho83 like this.
  13. Sep 7, 2023 at 5:32 PM
    TundraDan723
    True
    This is a great suggestion and one I thought of, however the Orbi mesh network "supports up to 75 devices". I currently have over 60 devices and I didn't want to push the limits and start causing QOS issues with important devices like laptops, printers, etc.
  14. Sep 7, 2023 at 5:33 PM
    TundraDan723
    To clarify, the password to both networks are the same, however the network names are different.
  15. Sep 7, 2023 at 5:46 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The network names are irrelevant.
