HELP WITH LIFT KIT
Discussion in 'Suspension' started by Hawaii2wacoTRD, Mar 21, 2022.
  1. Mar 21, 2022 at 7:40 AM
    Hawaii2wacoTRD
    Hawaii2wacoTRD [OP] New Member
    mike
    2014 Magnetic Grey Tundra TRD
    Rough Country 2.5 front leveling kit Bilstein 5100s Rolls Royce Starry Ceiling Lights
    what is the differences between: Superlift 3 inch with fox shocks, the bds suspension lift 4.5/3 strut mount and the rough country 3.5 bolt on lift kit with v2 shocks and vertex coilovers?
    OR
    does anyone have any recs for lift kits from 3-4.5 inches, I am trying to stay under 2100.
  2. Mar 21, 2022 at 10:07 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Superlift 3" Lift with Fox Shocks will be a spacer lift and rear blocks.
    BDS Suspension lift will be a bracket lift, with spindles, and blocks.
    RC 3.5 will be your ideal bolt on kit. Front coilovers with RR, but in the rear, you'll still be running blocks unless if you upgrade to a shackle, AAL, or a new leaf pack.
    Out of the 3, I'd say the RC 3.5 would be more ideal. But then again, that's also based on what you're doing on the island.
    Others will definitely chime in as well!
  3. Mar 21, 2022 at 10:09 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
