Help With LED Headlights
Discussion in '2.5 Gen Tundras (2014-2021)' started by tundraisland, Nov 23, 2024.
  1. Nov 23, 2024 at 11:20 PM
    tundraisland
    tundraisland [OP] New Member
    I just installed LED headlights on my 2017 that previously had the regular old halogens. I put the headlights on with no problems connect all the parts of the harness and got the headlights running perfect. I tested both by simply using hazards and they work great. I only realized once I put my left blinker on that it goes super quick. The right one was fine for a while, then suddenly also started going quickly, but then switched back to normal blinker speeds.
    I am super stumped on what is going on. The left only goes fast when using the left turn signal and not when using the hazards.
    Has anybody had a similar issue or know how I can fix this? Thank you!
  2. Nov 24, 2024 at 3:48 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Oem led headlights or aftermarket?
    You need resistors if you are using led turning bulb to prevent hyperflashing. Put back the incandescent bulbs and see if it cures the quick flashing. If it did, get some load resistor for your led turning bulb. Or get the led bulb that has the resistor build in..
  3. Nov 24, 2024 at 6:11 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    What wiring harness are you using? If it isn't ihacker, it should be.
    rodm1, 1lowlife, KNABORES and 2 others like this.
  4. Nov 24, 2024 at 7:55 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  5. Nov 24, 2024 at 8:28 AM
    tundraisland
  6. Nov 24, 2024 at 8:29 AM
    tundraisland
    They are aftermarket. But i bought them because they were “plug and play”. It’s not just one bulb either, it’s the whole flashing turn signal sequence. Thanks for your response!
  7. Nov 24, 2024 at 8:44 AM
    BrandonL812
    Brandon
    What’s the brand? Sounds like you should return them.
  8. Nov 24, 2024 at 11:11 AM
    tundraisland
    Vland, someone told me they were really good. Should have know based on the price that they would suck.
  9. Nov 24, 2024 at 11:14 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    There are a couple threads on this issue with after-market headlights.
    They may come up in a search..
  10. Nov 24, 2024 at 2:41 PM
    Oolypoolay
    Oolypoolay Meh
    2015 Limited Crewmax
    Bilstein 6112/5160 Method 702 0 offet Toyo open country 285/75 17 Form led headlights OEM Toyota led fog lights Morimoto 3rd brake light Morimoto tail lights Amp Research power steps
    If they came with the second harness for the DRL that's probably why. The DRL delete module from Morimoto fixed the hyper flash on my headlights. Some companies sell the headlights with an optional resistor.
  11. Nov 24, 2024 at 2:48 PM
    BrandonL812
    Brandon
    Better send them an email for support. To see what they can do for ya.
    rodm1 likes this.
