Intermittent ticking that goes away if I turn lights on
Discussion in '2nd Gen Tundras (2007-2013)' started by Cbauer9811, Jun 3, 2025 at 3:05 PM.
  1. Jun 3, 2025 at 3:05 PM
    Cbauer9811
    Cbauer9811 [OP] New Member
    Tuesday
    2007 Tundra TRD 4.7
    Bought with trailer brake modification
    I have a 2007 Tundra TRD 4.7, it is a 3rd vehicle for camping, jetskiing, etc.
    I opened the garage one night & saw the tail lights flashing then went off. Eventually battery went dead. Charged it - in addition, when turned on, a ticking sound from the inside fuse box was is heard. I noticed the lights inside (clock/outside temp) were dimming at the same time. I changed the brake toggle switch and checked fuses. I heard it could be a relay switch- how do i find out which one?
  2. Jun 3, 2025 at 3:22 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    That ticking is probably going to be a bad relay. You can actually feel it clicking on and off if you put your hand on the relays while it’s clicking.
    Bob and joseph_womack like this.
  3. Jun 3, 2025 at 3:51 PM
    Cbauer9811
    Tuesday
    2007 Tundra TRD 4.7
    OMG - I just did and can feel the fuel pump relay!! TYSM
    Carolyn
    ZappBrannigan and joseph_womack like this.
  4. Jun 3, 2025 at 4:05 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    Do yourself a favor and buy a new one from the dealer, one’s from Amazon are knock off and not oem Toyota
    if you get one from a parts store get a Denso one
  5. Jun 3, 2025 at 5:44 PM
    Cbauer9811
    Tuesday
    2007 Tundra TRD 4.7
    I bought the dealer one.
    Could it be more than one relay? I replaced the fuel pump relay - the ticking noise went away but came back just not as bad.
  6. Jun 3, 2025 at 6:55 PM
    Cbauer9811
    Tuesday
    2007 Tundra TRD 4.7
    Other relays are vibrating. The weird thing is it is attached to the instrument panel lights because they flicker until I turn the light switch to the parking ? (1st line) not headlights. Then it goes away
  7. Jun 3, 2025 at 7:13 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    It could be any number of things. Could just be a bad battery causing odd electrical issues. There could be something back feeding into the relay. There could be a bad switch. It’s possible some rodents got into the wiring. It could be a bad ground somewhere. Could be water ingress… there’s just so, so many things.
    Is there any more information you can give us? Mileage? Storage conditions? You tow jet skis with it, do these go in salt water?
    I imagine as a third vehicle it isn’t driven much. So my first inclination is battery related, and or rodent damage, or maybe a corroded ground.
    I would visually inspect the wiring harnesses first. I would check for signs of rodents in the cabin filter and under the hood where the truck pulls in air for said filter. I would also look in the engine air box.
    Can you give us any more information? Water ingress into the vehicle maybe? Anything out of the ordinary?
    do you have a multimeter and how comfortable are you with trouble shooting? What’s your level of experience here?
    joseph_womack likes this.
