Help with hyperflash and taillights
Discussion in 'Lighting' started by JROCK915, Nov 1, 2015.
  1. Nov 1, 2015 at 4:58 PM
    JROCK915
    JROCK915 [OP] Trust noone, and be prepared!
    Jeremy
    Palm Desert, CA.
    2011 Trail ready SR5
    Icon 1.5" leaf pack, w/ Pro Comp 1" block Rear Pro Comp SS shocks ToyTec/Eibach coil overs, on Pro Comp SS shocks, SPC UCA AFE Stage II C.A.I, and throttle body spacer N-Fab nerf bars N-Fab RSP front bumper with Hella Optilux 30" LED bar, and Hella Optilux 4" (2) HID driving lights Federal Couragia 33x12.5x20, wrapped around 20x9 Fuel Boost Fender flares Spyder LED tail lights (smoked out)
    Looking for some professional expertise!
    HYPERFLASH!!!
    I swapped out my tail lights for a better/nicer brand. Even when the tail lights were out, AND disconnected, I was still getting hyperflash on the driver's side.
    I have led switch backs up front, led 3157's for rear flashers and reverse. I do have resistors wired in. It's only the driver's side.
    Any suggestions??? Thanks in advance.
  2. Nov 2, 2015 at 11:31 AM
    Same bulbs or different bulbs put in? Sometimes the bulb can be inserted (on a led) wrong causing no contact
    JROCK915[OP] likes this.
  3. Nov 2, 2015 at 11:37 AM
    JROCK915
    Jeremy
    Palm Desert, CA.
    Same bulbs. Didn't think to think that, if it were in backwards, it would still hyperslash. Previous bulbs wouldn't even flash, when placed incorrectly. I'll check that. Thank you.
    T-Rex266 likes this.
  4. Nov 2, 2015 at 11:39 AM
    JROCK915
    Jeremy
    Palm Desert, CA.
    Is a 50w 6Ohm resistor too much? I had a difficult time finding any 3Ohm, that would ship fast enough.
  5. Nov 2, 2015 at 11:44 AM
    alalmcgrath
    alalmcgrath Old Fart at Large!
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    Put two 6 ohm resistors in parallel - that is the same as one 3 ohm resistor!
  6. Nov 2, 2015 at 12:01 PM
    @csuviper is pretty good with electrical too.
  7. Nov 2, 2015 at 12:11 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    Do you mean, one for the front switchbacks, and one for the rear flasher, each side?
  8. Nov 2, 2015 at 1:16 PM
    alalmcgrath
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    I am not familiar with Tundra wiring but I do know that two 6 ohm resistors in parallel is equivalent to 3 ohms. Wherever it calls for 3 ohms you can use two 6 ohms (or four 12 ohm) instead of one 3 ohm resistor . Just make sure they are wired in parallel.
    And the reason it hyperflashes with the bulbs removed is because the resistance is infinitely high(much higher than 3 ohms) called for.
  9. Nov 2, 2015 at 1:47 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    But the passenger side was good. That's what's throwing me off.
  10. Nov 2, 2015 at 1:50 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Cant help you with hyper flashing as i haven't installed LED turn signal bulbs yet.
  11. Nov 2, 2015 at 2:06 PM
    alalmcgrath
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    Did you try swapping resistors left to right side? If the problem moves I would suspect a bad resistor.
    It is also possible that a wire or socket was damaged (creating an open circuit) while doing the swap.
  12. Nov 2, 2015 at 2:15 PM
    alalmcgrath
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    Possible damaged wiring or socket causing an open circuit.
    I would swap all bulbs and resistors from left to right side to eliminate defective parts as a possibility.
  13. Nov 2, 2015 at 3:25 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    Good idea. I have plenty. I'll just replace it for s&g's!
    If that doesn't work, I'll check the prongs & connectors. Thanks.
  14. Nov 3, 2015 at 1:05 PM
    alalmcgrath
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    Any progress?
  15. Nov 3, 2015 at 1:17 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    I'll know after work today. Was waiting on another part from Toyota. Picked that up this morning.
  16. Nov 3, 2015 at 5:37 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    Still hyperflashing driver's side only. No tail lights. brake, hazards are right flasher are fine. WTF??!!??
  17. Nov 3, 2015 at 6:05 PM
    At this point I'm going to say a loose/damaged contact somewhere.
  18. Nov 3, 2015 at 6:25 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    question..... if I splice the wires for the resistors, will thst kill the circuit loop?
  19. Nov 3, 2015 at 6:34 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    Figured out the hyperflash. All lights work, except the tail lights. I have brake, hazards, flashers and reverse. NO tail.
  20. Nov 3, 2015 at 6:34 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    The passenger side rear harness is brand new.
  21. Nov 3, 2015 at 7:47 PM
    csuviper
    Broomfield, CO
    Hmm so now everything works except tail lights with lights on? Brake light works though?
  22. Nov 3, 2015 at 8:02 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    Yes sir, that is correct.
  23. Nov 3, 2015 at 9:19 PM
    csuviper
    Broomfield, CO
    Very strange. At this point fuse is all i got.
  24. Nov 3, 2015 at 9:27 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    That was my thought too. The only fuse box I know of if the one next to the batt. (2011 DC SR5). Checked 'em all. One by one. All good. Gonna head to Toyota tomorrow. Thanks for the help though.
  25. Nov 3, 2015 at 9:33 PM
    Check the one by the foot panel?
  26. Nov 3, 2015 at 9:35 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    I thought there was another. Just didn't know where to look. Was just about to Google it.
  27. Nov 3, 2015 at 9:42 PM
    Ya foot panel area.
  28. Nov 3, 2015 at 9:43 PM
    csuviper
    Broomfield, CO
    Look straight up under where your left foot rests.
  29. Nov 3, 2015 at 9:49 PM
    csuviper
    Broomfield, CO
    Cover looks like this
  30. Nov 3, 2015 at 9:57 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
