Help with fuel injector install
Discussion in '1st Gen Tundras (2000-2006)' started by Voss, Mar 19, 2021.
  1. Mar 19, 2021 at 6:05 PM
    Voss
    Voss [OP] Dust in the wind
    Valod
    2003 AC TRD 4x4
    I am again asking for your help. @Professional Hand Model and anyone else.
    took out all the bolts but still pretty tight in there.
    I feel like this is going to break if I pull up on the entire unit
  2. Mar 19, 2021 at 6:14 PM
    Voss
    Valod
    2003 AC TRD 4x4
    This is a metal line above the fuel injectors. How do I get around it?...
  3. Mar 19, 2021 at 6:53 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Tundra2 and Darkness like this.
  4. Mar 19, 2021 at 6:55 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Un do that clamp, that thing it’s attached to is attached to the rail, take the clamp loose and take channels and gently grip the tube and twist to break the seal then it should pop off, then pull that rail, you got this
  5. Mar 19, 2021 at 6:56 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Ok let’s give it a go thanks!
  6. Mar 19, 2021 at 6:58 PM
    FrenchToasty
    Mo
    Bone stock
    so you loosened both bolts on each side of that thing connected to the hose, pull the hose, pull that thing(it’s a pressure regulator or dampener if I recall) and it will pop off,(I’ve replaced mine) also maybe get your long eye ball and see where that metal line connects too, I don’t recall having to mess with it that, following hand models pictorial.
  7. Mar 19, 2021 at 7:08 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Ok getting there! Front is almost ready to come out, took out the middle but the back metal pipe is not allowing much movement.
    For anyone seeing this in the future, there’s a washer between the pipe In front and fuel injector pipe.
    Got this off, thanks!!
    but this pipe doesn’t seem to want me to remove the fuel injector pipe...
    Darkness likes this.
  8. Mar 19, 2021 at 7:26 PM
    Voss
    Valod
    2003 AC TRD 4x4
    For future strugglers like myself, there’s a bolt holding the back pipe in place, once removed you can move the metal pipe up. Even then tho I don’t see how the entire fuel injector pipe would come out so I’m going to try and replace the fuel injectors by pulling the pipe as far up as I can. Whoop whoop
  9. Mar 19, 2021 at 8:14 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Ok on the 2003 it’s apparently impossible to remove the entire fuel injector pipe unless you remove the entire top section of the engine(manifold if I’m not mistaken). You can get it high enough to remove the fuel injectors but then it’s basically impossible to put the new injectors on cause you can’t get enough leverage to push them back in.
    There simply isn’t enough space for the fuel injector pipe to come out
    Screwed. Can’t put new injectors on and can’t put old injectors back on. Lovely
  10. Mar 19, 2021 at 8:17 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    eek. i cant say i've had injectors off on an older 4.7. if its like alot of the older toyotas, the plenum has to come off. (sorry i havent been around today... otherwise i would of warned you sooner!)
    I think PHM has the same style manifold though
    Darkness and Voss[OP] like this.
  11. Mar 19, 2021 at 8:18 PM
    empty_lord
    05 rollover special
    oh wait. that engine hook, did you try removing it?
  12. Mar 19, 2021 at 8:21 PM
    Voss
    Valod
    2003 AC TRD 4x4
    My dude, appreciate the input! I got 2 more days to figure it out lol
  13. Mar 19, 2021 at 8:22 PM
    Voss
    Valod
    2003 AC TRD 4x4
    No how do I remove it?!??! That’s what’s in my way but I see no bolts for it. Maybe in between in the slot there? Let me check it out
  14. Mar 19, 2021 at 8:23 PM
    empty_lord
    05 rollover special
    i dont remember off the top of my head, BUT it should just be 2 bolts somewhere at the bottom
  15. Mar 19, 2021 at 8:25 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Ok I see them, backside of the mount towards the engine. Wouldn’t be able to get to them unless things were loosened up as much as they are. Let’s get this hook removed! Thanks!!
  16. Mar 19, 2021 at 8:33 PM
    Voss
    Valod
    2003 AC TRD 4x4
    To anyone thinking of doing this in the future and ur basically a dumbass like me, don’t try to do this lol. Good lord even the engine mount bolts are basically unreachable
  17. Mar 19, 2021 at 8:46 PM
    Voss
    Valod
    2003 AC TRD 4x4
    My background is in construction and when shit didn’t go your way in construction you hit it with a hammer!
    Engine mount now allows enough space for the fuel injector pipe to be removed.
  18. Mar 19, 2021 at 8:58 PM
    FrenchToasty
    Mo
    Bone stock
    Yay! Sometimes I like wearing gloves, other times I can fill a thirst buster cup full of hand sweat and end up ditching them. I don’t model with mine so I usually ditch them, but try to be gentle on the knuckles.
  19. Mar 19, 2021 at 9:10 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Lol. Fuel injectors on!
    Gotta admit I did call in a good friend to help... Old man helped me calm down with his old age wisdom.
  20. Mar 19, 2021 at 9:14 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Missing a seal or boot on that first one.
    Voss[OP] likes this.
  21. Mar 19, 2021 at 9:30 PM
    Voss
    Valod
    2003 AC TRD 4x4
    This can’t be good. Seems like a piece of the old injector rubber bushing is about to fall into where the bottom of the fuel injector goes...
  22. Mar 19, 2021 at 9:33 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Good catch. I only noticed after trying to install. Good thing too or else I wouldn’t of noticed the old piece about to fall into the engine. Now I’m worried if pieces haven’t already fallen in...
  23. Mar 19, 2021 at 9:37 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Take a look-see. Most use shop rags or paper towels to "plug" those engine holes from debrizzle
    Voss[QUOTED][OP] likes this.
  24. Mar 19, 2021 at 9:39 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Future folk take note. Don’t make the same mistakes I did. Let’s hope the 4.7 burns and spits it all out
    Tundra2[QUOTED] likes this.
  25. Mar 19, 2021 at 9:58 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Look in the holes before you have every thing together.
    Might be a big chunk in there. I've never been inside the 4.7L but you don't want to make something potentially go bad.
  26. Mar 19, 2021 at 10:04 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Brother it’s all gone bad. This is not something someone who doesn’t know a lot about mechanics should do. I dropped a bolt now and it’s under the manifold. Lol.
  27. Mar 19, 2021 at 10:18 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Again, I say that I have never laid eyes on the internals of the 4.7L.
    Unless you can get a magnet in there, and fish it out from under the manifold then it has to come back off to get the bolt. Maybe not, but probably.
    Don't want any loose things going crunch at 3,500 rpm
  28. Mar 19, 2021 at 10:35 PM
    Voss
    Valod
    2003 AC TRD 4x4
    got it. Here’s to having old school tools from your pops
    41034122-56BC-468C-A320-12545605D261.jpg[/QUOTE]
  29. Mar 19, 2021 at 10:48 PM
    Voss
    Valod
    2003 AC TRD 4x4
    The “easy” side it done. Only took about 6hrs lol. Hopefully I didn’t drop anything in the fuel injector holes that can destroy my engine. Tomorrow I’ll tackle the hard side lol. Atleast I’m enjoying it all
    Filthyphil and Tundra2 like this.
  30. Mar 19, 2021 at 10:49 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Sorry Voss, I haven't messed with them on my truck. Looks like you're getting through it though
