Help with disabling the orange DRL on 2016 - SR5
Discussion in 'Lighting' started by TuffTundra, Sep 9, 2017.
  1. Sep 9, 2017 at 7:19 PM
    TuffTundra
    TuffTundra [OP] New Member
    Missouri
    2016 MGM SR5
    4" Rough Country Lift - Fuel Assault 20x10 - Nitto Ridge Grapplers 33x12.5x20 - 2018 LED Headlights - LED Lights all around - No Chrome - Tinted Windows & Tail Lights
    Wondering if anyone has disabled the orange DRL on their 2016 SR5 (NOT a limited or 1974)Tundra. I have seen photos of how to disable it on a 2015 with removing the drivers side kick panel and cutting a grey wire. However, when I removed the kicker panel on my 2016 the wiring looks different. Any information/instructions would be appreciated.
    From what I read cutting this grey wire will disable the DRL but the light will still work as a signal light.
    Please post some photos if possible.
    Thanks for all your guys help with this!
    autosport209 and jp_over like this.
  2. Sep 9, 2017 at 7:40 PM
    TuffTundra
    Missouri
    2016 MGM SR5
    Well after searching around on the internet, help that was given to me by another member, and me searching more on my truck I think I found the grey wire to cut.
    For those wanting to do the same thing this is what you need to do:
    Remove the kicker panel on the drivers side.
    Remove the dash board bolt that was uncovered when you removed the kicker panel. Should need a 10mm socket to remove it.
    With a little force put out the dash board where the switches are at.
    Once you have this pulled out look behind the dash board side you pulled out and on the right hand side you will see the grey wire you will need to cut.
    For photos look at this link that was provided to me by another member.
    http://www.tundratalk.net/forums/tundra-lighting-electrical/489137-drl-disable-2015-a.html
    For those of you that have done this please let me know if this is correct and that this will disable the orange DRL but will keep them working as turn signals.
    Thanks everyone!
    autosport209 likes this.
  3. Sep 9, 2017 at 7:46 PM
    So turning and parking lights work? First mod i did was fogs lights on when you turn parking lights switch on...but i would like fogs with DRL
  4. Sep 9, 2017 at 7:49 PM
    This work for 2014?
  5. Sep 9, 2017 at 9:06 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Huh....that's a cool mod.
    I like the DRL's though. Changed mine to white instead of amber.
    Tundyfundy and (deleted member) like this.
  6. Sep 10, 2017 at 3:22 AM
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    I replaced my flasher assembly with part number 81980-0C020 shop around a bit though because some dealers are pretty expensive, I got mine for around $60 shipped. Everything functions normal just no DRLs. I can't take credit for this, I saw it on either this site or another.
    RitcheyRch likes this.
  7. Sep 10, 2017 at 3:30 AM
    Whocares
    Whocares Member
    I did the same. Same process as above, just no cutting of any wires involved. Replaces the OEM assembly relay and now -
    Off- no headlights, no drls , no fogs, no rear lights
    1 click - no headlights, drls on, no fogs, rear lights and license plate lights on
    2 clicks - all lights are on (fogs still adjustable)
  8. Dec 27, 2017 at 1:41 PM
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    Bringing this back up. Ok, my question is, is the grey wire you need to cut under the dash, the same grey wire at the drl bulb socket. It's a lot easier to cut it, than to start pulling kick panel and lower dash, not a fan of that. Bit the is 3 wires to the bulb socket. Hopefully I can cut it instead.
    My truck came with the dealer installed led strips that are below the headlights, I can turn them on without headlights on, for a led drl, but they clash with the amber drl's.
  9. Dec 27, 2017 at 1:44 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Try this on for size:
    1. With truck off, engage e-brake.
    2. Turn truck on.
    3. Take off e-brake
    4. DRLs are now off!
    We will need to do this each time you turn on your truck, but eliminates having to cut wires if you don't want too.
  10. Dec 27, 2017 at 1:50 PM
    easleycrawler
    Travis
    Yep, but I want them off all the time.
    This is with e brake on. Just led drl's.
    This is as soon as ebrake comes off. Both, Amber and LED's.
    I just want the amber drl's off permanently. Just hoping I can cut a wire at the bulb.
  11. Dec 27, 2017 at 2:00 PM
    TXMiamiFan
    Jose
    I see that now. I don't have those pretty lights . . . sorry I couldn't help.
  12. Dec 27, 2017 at 2:01 PM
    easleycrawler
    Travis
    No problem. Just hoping someone will.
    TXMiamiFan[QUOTED] likes this.
  13. Dec 28, 2017 at 3:32 AM
    TTund16
    TTund16 New Member
    based on what you are saying, the DRL should stay off until:
    1- you stop the car and engage the e-brake ...
    2- turn the car off
    3- start the car and then disengage the e-brake.
    is that right?
    I know some people that won't engage the e-brake when on a flat spot. they just turn the car off and put it in PARK.
    wonder if it does the same thing (No DRL). it is basically same as what you are saying except in step 1 you don't engage the e-brake and also no need for step 3.
    This would unintentionally turn the DRL off. either way sounds like a loophole in the design. lol
  14. Dec 28, 2017 at 4:33 AM
    TTund16
    TTund16 New Member
    without having the wiring diagram and in general ...
    in some cars there is wire to control the DRL. if the control wire is powered it turns off the DRL. for example the control wire can be connected to headlights or the high beams, this way when the headlights are ON or if the high beam is ON, it will turns the DRL OFF.
    it would be an easy test. you will need a voltmeter or voltage tester.
    btw, I am just answering the technical part of your question and am not recommending to turn the DRLs OFF obviously they are for visibility and safety reasons ... they are mandatory in Canada and i assume maybe in some or all? states in the US ... at least mandatory for new(er) cars ...
    come to think of it, Tundra DRLs are also turn signal and that may change things a bit since you don't want to disable the turn signal! also I don't know if the bulbs are single or double filament. You may have to experiment with the voltmeter and see if you can control it at the bulb assembly or not!
  15. Dec 28, 2017 at 5:42 AM
    easleycrawler
    Travis
    Thanks. I know they are for safety, but hell I'm running 2 sets of drl's, one has to go. I may just take the kick panel and lower dash off and cut the gray wire.
  16. Dec 29, 2017 at 7:31 AM
    Sting Ray
    Sting Ray New Member
    Ray
    Vegas
    2017 SR5 Crewmax
    Not enough space here...
    You could depin that wire instead of cutting it. Will make it a lot easier to go back to original configuration later on if you choose to do so. I just recently installed 2018 lights and disabled my amber drl's. It's the gray wire that was between the white with black stripe and the green it's removed in this pic, 5th down from the top left IMG_5809.jpg
  17. Feb 14, 2019 at 4:25 PM
    mttjdy
    mttjdy New Member
    Are your ambers still coming on when the headlights are fully turned on though? I installed the 2018 Sport LEDs, I don't have ambers while the led drl is on but once I flip the full headlight on, ambers light up as well. This is with the grey wire clipped..
  18. Feb 14, 2019 at 4:28 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    No not at all. the ambers don’t come on whatsoever unless I use turn signals.
    jp_over likes this.
  19. Feb 14, 2019 at 4:31 PM
    mttjdy
    mttjdy New Member
    Hmmm. Well I'm lost then haha. I installed OEM 2018 Sport led headlights with headlight revolution harness and DRL adapter, as I did not have factory DRL, just amber parking lights. Clipped the thin grey wire and still have amber turn signals lighting up full time when the headlights are on
    Sucia likes this.
  20. Feb 14, 2019 at 4:32 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Not sure man. I bought my harness from @iHacker I’m not familiar with the harness you speak of. Sorry I couldn’t be more help.
  21. Feb 14, 2019 at 4:38 PM
    mttjdy
    mttjdy New Member
    No worries!
  22. Mar 3, 2020 at 4:08 AM
    jp_over
    jp_over New Member
    Joe
    East TX
    2017 CrewMax SR5 4x4, white
    This is exactly what I'm looking for. I'm going to do this mod today (2017 SR5 CM w/ 38k miles).
    What got me here is having a front signal light go out yesterday and then, upon inspection, I found evidence of overheating / discoloration on both signal sockets.
    I'm going to replace both amber signal bulbs and sockets with OEM and then do the DRL disable mod to hopefully eliminate changing bulbs and/or damaged sockets on a regular basis due to overheating.
  23. Mar 3, 2020 at 11:35 PM
    TTund16
    TTund16 New Member
    Did you have a non-oem bulb or TX heat?
  24. Mar 4, 2020 at 4:22 AM
    jp_over
    jp_over New Member
    Joe
    East TX
    Did the job yesterday. I bought my truck used (22k miles or so) but both bulbs had OEM labeling.
    We do have TX heat but it's east TX so not the kind of temps you'd see in other parts of TX out west.
    The bulbs and sockets were 10 minutes but it took me over an hour to de-pin the DRL wire with a safety pin. Then I shrink wrapped the end and zip tied it out of the way. I'm going to pick up a proper de-pinning tool for future use. All lights tested great with no DRL.
    This thread and video were vital to the DRL mod:
    https://www.tundras.com/threads/201...lay-harness-for-2014-2020-models-v-2-0.24416/
    https://www.youtube.com/watch?v=m0WBZMPKoss
    wyoboypt and TTund16[QUOTED] like this.
  25. Mar 4, 2020 at 5:57 AM
    DXO
    DXO New Member
    South Shore, MA
    2014 Crewmax Limited
    I did this mod yesterday too for the exact same reason, looks like a lot of heat with the DRL on. Was about to give up and cut the wire and the extractor finally worked (or rather I finally figured out how to use it correctly).
    jp_over[QUOTED] likes this.
  26. Mar 4, 2020 at 6:32 AM
    jp_over
    jp_over New Member
    Joe
    East TX
    DXO - what extractor did you end up with?
  27. Mar 4, 2020 at 6:48 AM
    DXO
    DXO New Member
    South Shore, MA
    I picked this set up on Amazon for 9.99.[​IMG]
    Had I really understood how the pin is held in I may have tried a needle first, not sure what other use I'll have for these.
    TTund16 and jp_over like this.
  28. Mar 4, 2020 at 12:11 PM
    TTund16
    TTund16 New Member
    I haven't looked inside the drl housing but if my car is idling for a while, the drl cover gets pretty warm ... Once you drive the cover cools off but I'm not sure if the air flow can impact the inside as much.
  29. Mar 8, 2020 at 6:12 AM
    jp_over
    jp_over New Member
    Joe
    East TX
    As an FYI, here's a pic of the damaged socket / old bulb next to the new on (new top, old bottom):
    Also, the OEM socket part #:
    TTund16 likes this.
  30. Mar 8, 2020 at 1:26 PM
    TTund16
    TTund16 New Member
    iirc, the drl bulb has 2 filaments. No?
    I think when the headlights are on, the drl is turned off but the low power filament inside the drl (parking light) stays on. Or maybe when you start the engine and still in PARK and turn on parking/side lights, the lower power filament turns on. But as soon as emergency brake is released the main (high power filament) drl light comes on.
