Help with 285/75R18 rubbing
Discussion in 'Wheels & Tires' started by tundratrav82, Aug 15, 2015.
  1. Aug 15, 2015 at 8:34 PM
    tundratrav82
    tundratrav82 [OP] Nevada Tundras
    travis
    winnemucca, NV
    2011 tundra limited TRD crewmax
    Limmo tint on all 3 rear windows, 20% in front two. 18" black ballistic rims with nitto tires Bike bar in the bed for my dirt bikes..
    Hi guys, gals
    So I was out running around the desert with stock size 4 ply tires and ended up getting a flat tire.. Took it to the tire shop and it had a nice gash in the tread.. Talked my wife into letting me buy new tires and she did.. I went with a 285/75 18 or 35/11.5 took my front flaps off and inner lower fender.. But at a semi sharp turn I rub on the cab mount that sits behind the front tires.. Will a wheel spacer help so it won't rub? Any thoughts would help.. Oh I have a toytec 3" spacer lift and 1.5 add a leaf in rear.. And 18" ballistics anvel wheels
  2. Aug 15, 2015 at 9:37 PM
    Just trim the front bumper and re-tap the lining back in.
  3. Aug 15, 2015 at 9:49 PM
    tundratrav82
    travis
    winnemucca, NV
    It's not in the front that I have an issue with.. It's the cab/ body mount right behind the front wheel..
  4. Aug 16, 2015 at 12:51 AM
    chphilo
    chphilo Tundra addict
    Western PA
    Ballistic Anvil comes with 12 mm offset and 0 offset. The way your tires rub, it sounds like yours is 0 offset. You need wheels with higher offset or smaller tires. Wheel spacers will make the rubbing problem worse.
    If changing the wheels or tires is not feasible, you will have to chop the body mount. I personally don't want to do it, so I went with 18 mm offset. But the process doesn't seem that bad. This link may be helpful (http://www.off-road.com/trucks-4x4/project/fixing-tire-rub-from-large-offroad-tires-53862.html).
  5. Aug 16, 2015 at 9:28 AM
    An, first pic looked like it was rubbing that front end pretty well, maybe I looked at it wrong. :anonymous:
    Have you considered a cab mount chop? I had the CMC done.
  6. Aug 16, 2015 at 9:29 AM
  7. Aug 16, 2015 at 10:47 AM
    tundratrav82
    travis
    winnemucca, NV
    Yes I have , trying to find a place the will do it. It's only the out side edge of the tire that rubs, that's why I was thinking about a wheel spacer.. Logic right? Push the edge of the tire out, it would have further to travel before contact?
