Help with 2000 tundra
Discussion in '1st Gen Tundras (2000-2006)' started by #1paintguy, Apr 20, 2019.
  1. Apr 20, 2019 at 11:08 AM
    #1paintguy
    #1paintguy [OP] New Member
    2000 tundta
    I recently bought a 2000 tundra it runs great but has a low idol as if its gonna stall out and go to give it has it dies. Previous owner had same issue. I put new battery in still nothing. Anyone run into this problem ? I'm fixing it myself
  2. Apr 20, 2019 at 12:21 PM
    Eugene406
    Eugene406 New Member
    Montana
    2002 Toyota Tundra SR5 TRD
    Bone Stock.
    Hey Paint,
    Welcome, do you have any active codes at the moment? It can take some time for your truck to relearn after you swap in a new battery (go for a drive atleast 30 minutes), this should fix the problem. If not, it is likely your throttle body could use a good cleaning. When was the last time the plugs were replaced? I would start with a general tune-up and replace your fuel filter while you are at it, quick and easy job.
    Good Luck
  3. Apr 20, 2019 at 2:02 PM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    Look for vacuumed leaked/ broken hoses then clean throttle body . Check spark plugs . Check or replace fuel filter
  4. Apr 21, 2019 at 6:13 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I'd recommend taking a look at the MAF sensor too. Clean it up along with the throttle body. Take the truck somewhere to have the fuel filter replaced. It's not worth the pain for the few bucks you'll save.
  5. Apr 28, 2019 at 7:21 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Change your spark plugs
  6. Apr 29, 2019 at 9:40 AM
    faviles
    faviles New Member
    2001 Red Tundra SR5 TRD
    Stock for now
    I had this same problem as well. Changed plugs, cleaned throttle body, checked spark, changed fuel filter. After all of that the problem was still there. Did a compression test and cylinder number 7 was about 165 while all the others were in the 210-215 range. Hoping this isn't the case with yours but I would check compression to rule this out.
  7. Apr 29, 2019 at 9:52 AM
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    I have a 2000 tundra with 376,000 miles that I bought new. Everything that has been said is right.One of those things should take care of the problem. good luck!
  8. Apr 30, 2019 at 11:50 AM
    00TundraZ
    00TundraZ New Member
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    My personal experience with low idle...
    I properly cleaned the MAF and really spent a good amount of time cleaning the throttle body (wow was it is dirty!). Fixed my idle immediately. Couldn't believe the difference. Good some good cleaner and really get in there. Don't be afraid to open up the throttle body and clean the back of it as well, that was where it was very dirty. I bought the more expensive blue 'shop rags' that are really just thick paper towels. They were a life saver on this project.
    After this I changed the PCV valve/grommet & replaced the air filter for good measure.
    Any questions, just ask away! Best of luck on getting this fixed!
  9. Apr 30, 2019 at 12:53 PM
    YotaManSD11
    YotaManSD11 New Member
    Leo
    2005 Tundra Sr5 TuRD
    Replace air filter, clean throttle body, clean MAF sensor. Fixed my idol issues in my 1st Gen right quick.
    bmf4069 likes this.
