Help!? Wire harness connector to fuel module broken
Discussion in '2nd Gen Tundras (2007-2013)' started by DavidBanner, Sep 5, 2019.
  1. Sep 5, 2019 at 1:52 PM
    DavidBanner
    DavidBanner [OP] New Member
    David
    2011 Tundra 5.7l double cab
    Hi, can anyone tell me where I can find the connector that plugs into the fuel module near the driver side rear wheel? Mine is broken and I don’t have the money to buy an entire new harness from Toyota ($2500+) I just need the pig tail.?? Any help would be great. Thanks
  2. Sep 5, 2019 at 1:54 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I’d start calling wrecking yards in the area. Maybe pull one off a totaled truck
  3. Sep 5, 2019 at 4:38 PM
    Rengawt
    Rengawt New Member
    Tanner
    2010 Tundra Crewmax 4x4 Platinum
    If the connector is still somewhat in-tact, there should be a 5 digit number that would correspond to the correct plug. It would be as follows 90980-xxxxx with the x's replaced with that number. The pigtail wires would be separate from that but I could find out the correct wires with the connector number.
    Black Wolf likes this.
  4. Sep 5, 2019 at 6:27 PM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    Do you have a pic
  5. Sep 5, 2019 at 6:28 PM
    Vince
    Vince New Member
    Vincent
    You could use zip ties to keep it plug together need a pic to see if that would actually work.
