Help! Warning light after level install!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Iscrewedup, May 30, 2021.
  1. May 30, 2021 at 6:04 PM
    Iscrewedup
    Iscrewedup [OP] New Member
    IDK what happened. Installed a Rough Country Leveling kit 3/1.5.
    front went in fine.
    after front install I got it aligned because it was close to closing time. Came home started to install the rear. Rear installed fine. Started it, no alarms. Put it in drive and the “master warning light” (exclamation point in a triangle) every time I get past 5 mph. No braking issues, no shudders, no noticeable issues, no other lights on, no codes!
    please help! Aww WTF did I do!
    (great first thread :facepalm: )
  2. May 30, 2021 at 6:09 PM
    Iscrewedup
    I did try searching as much as I could. So upset with myself
  3. May 30, 2021 at 6:31 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    No need to be upset, sounds like it will be something pretty simple. Welcome to the forum BTW. :thumbsup:
    So this problem didn't occur while driving back from the alignment, only after you did the back, correct?
    Also, what year is your truck?
  4. May 30, 2021 at 6:37 PM
    trucknut
    trucknut New Member
    2021 Cav blue SR5 TRD Off Road
    Do you have the parking sensors? I've heard for some folks after a lift those and/or the TSS ones need to be recalibrated
  5. May 30, 2021 at 7:19 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    There should be some other warning aside from the exclamation point...
    Are all your doors closed? Hood closed fully?
    EDDO and Occidentalis like this.
  6. May 30, 2021 at 8:22 PM
    Iscrewedup
    I double checked, it was my second thought after I put my seat belt on
  7. May 30, 2021 at 8:23 PM
    Iscrewedup
    I think I do.
  8. May 30, 2021 at 8:24 PM
    Iscrewedup
    No drove fine to and from alignment. Steering wheel was off center but no pulls or anything. Drive home was uneventful. It was only after I installed the rear lift blocks
    ‘21 CM 4wd limited
  9. May 30, 2021 at 8:24 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    Get codes read - I'm betting a wheel speed/ABS sensor somewhere.
  10. May 30, 2021 at 8:46 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Damaged ABS line would be my guess.
    2mchfun likes this.
  11. May 30, 2021 at 8:54 PM
    Iscrewedup
    That is my suspicion. My scanner does not read abs
  12. May 31, 2021 at 4:28 AM
    Iscrewedup
    Pic of dash, RPM and Speed
  13. May 31, 2021 at 4:41 AM
    Iscrewedup
    Welllll, I’m a $&@%ing idiot
    :facepalm: :facepalm: :facepalm:
    idk if any of you can see the issue from my pic, but I did. I moved the truck so my wife could get out. Parked it and went back to researching what I did wrong. Looked up and across the yard to see what… MY STUPID F-ing hood is open :facepalm:
    Closed the hood. Alarm is gone.
    I am so sorry for wasting everyone’s time! I have to say this is a good group of people willing to try and help.
    (Why the hell does Toyota not have a hood open alarm with every other alarm they put on this truck.)
    on a plus side the truck looks good
  14. May 31, 2021 at 6:06 AM
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    2008 Limited Crew Max
    Good to hear it was simple.
  15. May 31, 2021 at 7:19 AM
    Danman34
    Danman34 New Member
    Danny
    Your hood is open. Lol.
  16. May 31, 2021 at 9:20 AM
    Iscrewedup
  17. May 31, 2021 at 2:50 PM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    I was going to say hood latch. My buddy parked my truck when we launched the boat and pulled the hood latch to release the parking brake. He was in a panic something broke on the truck...took me a few minutes to figure out the hood latch. I feel your pain. :)
    2mchfun likes this.
