HELP Tundra - Crank no start
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bstanley45, Feb 19, 2025.
  1. Feb 19, 2025 at 6:39 PM
    Bstanley45
    Bstanley45 [OP] New Member
    Have 2015 tundra. Was sitting in it with it running and then it just bogged down and died. Had it towed to buddies barn and replaced the fuel pump. Still turning over with no start after new pump. Had someone come look at it and he said it was the Fuel pump control module. He bypassed the plug and it fired right up. Bought a new module and tried it today and it fired first try. Turned it off and was gonna take it on a test drive and back to square one with no start.
  2. Feb 19, 2025 at 9:16 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    How many miles? I would've probably started with plugs tbh. With it on, bogging and dying, could say battery as well.
  3. Feb 20, 2025 at 7:28 AM
    lr172
    lr172 New Member
    07 DC
    It seems that a common problem is the pins on the connector for the fuel pump module loosen up and create intermittent problems.
    dundunDUN likes this.
  4. Feb 20, 2025 at 3:48 PM
    dundunDUN
    dundunDUN New Member
    2016 Tundra SR5 CrewMax
    Yes, this. And with mine, the connector to the alternator was loose and the battery went bad on top of everything. Repaired the connector and replaced the battery and no issues since.
