HELP!!! Truck won't start after throttle body replacement - SOLVED
Discussion in '2nd Gen Tundras (2007-2013)' started by digdug, Jul 25, 2025.
  1. Jul 25, 2025 at 1:44 PM
    digdug
    digdug [OP] New Member
    Doug
    2008 Crewmax
    5" BDS Fox 2.5 BDS UCA TRD stabilizer Airlift wireless one 35x12.5 Venom Power Terra Hunter XT 20" Hard Rock Indestructible
    I replaced my throttle body and now my truck won't start, let alone try and do any of the re-learn processes. There is nothing that I can find to help me get this things started. It doesn't sound like it's getting any gas? I've checked all of my connections and they are all fine
  2. Jul 25, 2025 at 1:52 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    That's weird. Why did you replace the TB, that's not a real common thing to do. Have you tried to reinstall the original, just to be sure?
    e30cabrio and Mdl like this.
  3. Jul 25, 2025 at 2:35 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    OEM? With key on,not started, can you hear throttle body blade move when pedal pressed.
    Relearn: key on, press pedal slowly to floor and back to normal 3-5 times. Idle relearn:
    Wynnded and e30cabrio like this.
  4. Jul 25, 2025 at 4:38 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @digdug post up what it was. Helps out others that go through similar issues. Be it as simple as a loose plug or ?
    Wynnded likes this.
  5. Jul 25, 2025 at 4:39 PM
    digdug
    Doug
    2008 Crewmax
    All Good, I got it! One of the plugs wasn't completely in. I was so baffled. lol ... Thank you!
    bicklebok, Wynnded and Mdl like this.
  6. Jul 25, 2025 at 4:40 PM
    digdug
    Doug
    2008 Crewmax
    Sorry about that. I typed out what happened a bit ago, but I guess it didn't post
    Mdl[QUOTED] likes this.
