Help truck just died
Discussion in '2nd Gen Tundras (2007-2013)' started by Jodyryver, Dec 28, 2018.
  1. Dec 28, 2018 at 4:23 AM
    Jodyryver
    Jodyryver [OP] New Member
    Jody
    Hey I’m jody justbjoined forum and already need help my truck just died while driving and now won’t start the a/t oil temp light is on and the vsr vsq light as well anyone have any ideas.
  2. Dec 28, 2018 at 4:56 AM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Howdy from DFW and that sucks. Make sure truck is in park...not much help without being there
    Black Wolf likes this.
  3. Dec 28, 2018 at 4:59 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    year truck?
  4. Dec 28, 2018 at 5:00 AM
    ^^^ditto..except welcome from CO.
  5. Dec 28, 2018 at 5:46 AM
    Jodyryver
    Jody
  6. Dec 28, 2018 at 5:59 AM
    Does it try to start at all?
    Boosted4runner likes this.
  7. Dec 28, 2018 at 6:10 AM
    TundraAllTheWay
    TundraAllTheWay New Member
    2018 Cement Grey Toyota Tundra SR5 CrewMax TRD Off-Road
    Did you call the dealer? Also check and make sure your oils are topped up. Welcome from Alberta, Canada.
    NewImprovedRon likes this.
  8. Dec 28, 2018 at 8:02 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Sorry to hear about your issue. Welcome from CO tho.
  9. Dec 28, 2018 at 8:10 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Shot in the dark: pull the negative battery terminal for 10-15min
    Boosted4runner and OR18TRD like this.
  10. Dec 28, 2018 at 8:18 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Welcome from CO
  11. Dec 28, 2018 at 2:19 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I'd like to 2nd this ^^^ nomination.
  12. Dec 28, 2018 at 2:29 PM
    15whtrd
    15whtrd Mr. Blonde
    Find a schematic and make sure the wires leading to the sensor are good. Check all your fuses. Under the hood and in the kick panel on the driver side. Also who has been changing your oil? I suspect dealers aren’t always changing out the filters because they aren’t the easiest to access.
  13. Dec 28, 2018 at 2:43 PM
    Boosted4runner
    Boosted4runner Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    Welcome Jody, and sorry to hear your first post is an issue.
    What led up to the truck dying? Was there any indication prior - or just running at XXMPH and it shut down? Any headlight dimming or indication of loss of 12V power?
    I would assume truck is not low on fuel (have to ask).
    ColoradoTJ likes this.
  14. Dec 28, 2018 at 2:58 PM
    Welcome from CO.
    I wouldn’t do a hard reset on the ECM. Clears all codes and then you may not be able to properly troubleshoot.
