HELP! Truck died while driving, won't turn over, no codes.
Discussion in '1st Gen Tundras (2000-2006)' started by russianbear, Jun 2, 2025 at 5:50 AM.
  1. Jun 2, 2025 at 5:50 AM
    russianbear
    russianbear [OP] New Member
    Barrett
    Jacksonville FL
    2006 Tundra 4x4 Limited Double Cab
    Hello, I have a 2006 Limited 4x4. Driving down the road it just shut off. Will not turn over, does not show a code. Battery is only a year old and alternator is only a couple years old. Battery gage shows there is juice. Anyone have any ideas what this could be? HELP!
  2. Jun 2, 2025 at 5:55 AM
    Run all of the wires and grounds. Corrosion can cause these kinds of issues. Water intrusion can also cause issues with on board computers. Also worth testing the battery. New or old they can suffer from heat and vibration damage and "drop a cell".
    russianbear[OP] likes this.
  3. Jun 2, 2025 at 6:04 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Timing belt break? When was the last time it was done?
  4. Jun 2, 2025 at 7:29 AM
    shifty` No Fat Beaver
    First step so you're not beating your face on a wall: Pull the battery out. Go get it tested for free at the local auto parts store chain.
    You need to understand, a battery with 13V or higher charge won't be able to fire off the starter if it has no cranking amps (CA/CCA). Batteries are VOLTAGE and AMPERAGE, you need both to turn over a truck.
    Bad batteries happen. We see one every couple of months on here with 'no start' threads. Some are days/weeks old. Duds are a thing.
    Once you know the battery is good - obviously, answer Nick's question, b/c timing belt/water pump/tensioner are supposed to be done every 90k or 9yrs (100k/10yr is acceptable) if you're using OEM parts, the V8 is a low-interference engine and you'll potentially kill it if that belt snaps while driving.
    Likewise, if the timing belt WAS done, and you verify it's still intact by loosening the one of the timing covers and looking the belt is under tension, you need to verify the crank position sensor harness didn't get cut through by a pulley, it often gets mis-routed where it's not behind the accessory bracket, and gets clipped. Correct routing info here.
    russianbear[OP] and hammeron like this.
  5. Jun 2, 2025 at 7:59 AM
    russianbear
    Barrett
    Jacksonville FL
    It was done about 80,000 miles ago. Truck has 235,000 on it now
