Help! Truck cranks but won't start
Discussion in 'General Tundra Discussion' started by maxcala, Nov 14, 2019.
  1. Nov 14, 2019 at 8:21 PM
    maxcala
    maxcala [OP] New Member
    Max
    L.A.
    2014 Limited Crewmax
    Hi everyone,
    I haven't used my truck for 3 months and battery died. Charged the battery but won't start.
    Any ideas?
    2014 Tundra Crewmax Limited
    TIA,
    Max
  2. Nov 14, 2019 at 8:22 PM
    Stock battery?
    TheBeast likes this.
  3. Nov 14, 2019 at 8:22 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    Bad fuel?
  4. Nov 14, 2019 at 8:33 PM
    maxcala
    Max
    L.A.
    Yup, same battery before it was working.
  5. Nov 14, 2019 at 8:34 PM
    maxcala
    Max
    L.A.
    fuel Pump is good
  6. Nov 14, 2019 at 8:37 PM
    maxcala
    Max
    L.A.
    When i put the key in, the immobilizer still blinking. Is that normal?
  7. Nov 14, 2019 at 8:39 PM
    AZBoatHauler
    So.Arizona
    Sounds like the battery went bad. I’d start with replacing and see if that fixes your issue.
    NewImprovedRon and JimboSlice413 like this.
  8. Nov 14, 2019 at 8:39 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    The first thing i would do is to load test the battery. Its an easy test, but one that's pretty important. Hope this helps.
  9. Nov 14, 2019 at 8:45 PM
    maxcala
    Max
    L.A.
    I did the load test and it is still good. I went to auto zone and see if they can test the battery and i was told it is still good.
  10. Nov 14, 2019 at 8:47 PM
    maxcala
    Max
    L.A.
    Anyone know how to disable the immobilizer?
  11. Nov 14, 2019 at 8:52 PM
    AZBoatHauler
    So.Arizona
    The OEM batteries are known for testing good even when they’re causing the problem.
  12. Nov 14, 2019 at 8:53 PM
    stock batteries are horrible
  13. Nov 14, 2019 at 8:54 PM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    This is all true. My 17 battery was dead before the year mark.
  14. Nov 14, 2019 at 9:07 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
  15. Nov 14, 2019 at 9:12 PM
    maxcala
    Max
    L.A.
    I hear the fuel pump and see gas coming out of the fuel line.
  16. Nov 15, 2019 at 5:15 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Is the MIL lit ?
    edit....Just noticed your below question....just throwing out a WAG. Do you have another key to try ?
    JohnLakeman likes this.
  17. Nov 15, 2019 at 5:25 AM
    Trooper2
    JR
    Should be a good sign. Next you need to verify spark at plugs.
    The gas quality as mentioned could be an issue. If ignition / spark at plugs maybe replace fuel and try a product like mentioned in previous post.
    Gasoline doesn't have an infinite shelf life.
  18. Nov 15, 2019 at 5:37 AM
    chugs
    chugs New Member
    Ciao
    Central Cali
    Seafoam for the smoke show!
  19. Nov 15, 2019 at 6:54 AM
    maxcala
    Max
    L.A.
    Hey @BubbaW , What's MIL?
    I tried the other key with same result, the immo car key with LED still blinking when I put the key on.
  20. Nov 15, 2019 at 6:54 AM
    maxcala
    Max
    L.A.
    I'll try to get a new battery and see.
  21. Nov 15, 2019 at 7:07 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Maintenance Indicator Light
  22. Nov 15, 2019 at 8:44 AM
    maxcala
    Max
    L.A.
    When I start it, the Battery light and Engine light is lit.
  23. Nov 15, 2019 at 8:45 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Close.
    Malfunction indicator light.
    BubbaW[QUOTED] likes this.
  24. Nov 15, 2019 at 8:45 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    wasn’t good in math either :)
  25. Nov 15, 2019 at 10:35 AM
    chugs
    chugs New Member
    Ciao
    Central Cali
    Obd2 scan for any fault codes?
  26. Nov 15, 2019 at 10:48 AM
    15whtrd
    15whtrd Mr. Blonde
    Try your other key if you have one.
  27. Nov 15, 2019 at 12:10 PM
    AZBoatHauler
    So.Arizona
    Dollars to donuts a new battery fixes your issue.
  28. Nov 15, 2019 at 1:45 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    I don’t know many Bubba’s who were good at math. :p
  29. Nov 15, 2019 at 1:49 PM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    Crankshaft position sensor? You should get a code for it though
  30. Nov 15, 2019 at 1:56 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    :amen::hattip:
