Help the Newb: Headers w/ one set of cats, pass emissions?
Discussion in 'Performance and Tuning' started by Cuban11182, Aug 4, 2018.
  1. Aug 4, 2018 at 5:40 PM
    Cuban11182
    Cuban11182 [OP] New Member
    Hope Mills, NC
    2018 Tundra Limited
    Kings w/ adjusters, Icon Rebound with Discover AT3 LT 285/75/R17, Airlift bags, ARB dual compressor, OV Tuning,
    Just bought a 2018 Tundra Limited w/ the 5.7. From what I'm seeing, adding a set of JBA LT headers will still pass emissions as long as you have one set of cats, is that true? Can you go w/ high flow, or do they need to be stockers? I'm assuming that if it passes emissions, you wont' have any check engine lights.
    Thanks in advance.
  2. Aug 4, 2018 at 7:37 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    High flow cats generally won’t pass emissions. They do just enough to cut the smell and fuel vapors. Assuming you place the cats in the right area and function well, then you should get close to pass emissions. Passing emissions and not having a CEL are not exclusive. You can not have a CEL and still not pass emissions.
  3. Aug 4, 2018 at 8:11 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    dirtydeeds likes this.
  4. Aug 5, 2018 at 12:08 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    What state are we trying to pass emissions in?
  5. Aug 5, 2018 at 12:13 AM
    Stewie
    Stewie New Member
    2016 Crew Max
    What Keith said.. if youre in CA you will fail the visual inspection with just two cats.
  6. Aug 6, 2018 at 9:22 AM
    showtime240
    showtime240 New Member
    Can you just get the JBA midpipes and get an exhaust shop to put the factory cats on?
    trdprobped17 likes this.
  7. Aug 7, 2018 at 1:51 PM
    Cuban11182
    Hope Mills, NC
    2018 Tundra Limited
    It's NC, I believe it's just the OBD2 plug and not the sniffer.
