Help - tailgate inside plastic cover bolt locations?
Discussion in '3rd Gen Tundras (2022+)' started by raylo, Aug 22, 2025.
  1. Aug 22, 2025 at 8:04 AM
    raylo
    raylo [OP] not so new member
    Frederick, MD
    DashCam, amp & sub, DIY rear seat delete, cat shield, AMP power boards
    I have a small dent in my tailgate, and I was thinking I could maybe access it from the inside to tap it out, so I pulled the plastic cover off. Unfortunately, I can't really access the area with the dent since there is no hole in the tailgate metal frame there. Went to put the plastic cover back and I see that 6 of the bolts are different from the other 10. These have bigger heads with wider washers and are also longer. Can someone have a quick look and post up where those 6 bolts with the wider washers go? I looked at the onlline tailgate parts and it doesn't show that detail.... at least that I can find.
    I may have another go at this some time by using a hole saw over the dent to fit a metal drift in to tap it, with a dolly on the outside. Stupid dent isn't big, but it is a sharp crease and will need to be worked from the inside.
  2. Aug 22, 2025 at 8:19 AM
    raylo
    Frederick, MD
